Question about HP LaserJet 1000 Printer
Printer will not network
I have an HP LaserJet 1000 in my home office. A couple years ago, in another home office, I had it networked so both my computers would print from it, so I know it is possible to do. Now, in my new office, I have several computers hardwired through a workgroup - router box. We also have three personal laptops that we use wireless. Issue: only the computer physically hooked to the printer will print. Have enabled sharing and all that, but cannot make it work with the downloaded "newest" driver. Have been told the 1000 is a single-user machine but that there is a workaround - possibly a "general" driver? I know there is a way because I have made it work in the past. I just don't know how I did it, grins. We run Windows XP pro or home on all our machines. Thank you in advance for any assistance you can lend.
  • sunbow Dec 27, 2007
    Have the same problem. Was this issue resolved?
    Brigadier General:
  • 6,966 Answers
Hi Stukie, Something you can try. Install the downloaded "newest" driver in all you PCs and laptops even if they cannot see or share with the PC print server. If you can successfully install on each PC, then you try changing the port setting of the printer on each PC. Go to Start, Printers and Faxes, Right click on the HP LaserJet 1000 (assuming you were able to install on every PC), click on Properties, click on Ports Tab, Click on Add Port, Double click Standard TCP/IP Port. A new window will pop up > Add Standard TCP/IP Printer Port Wizard, in the IP Address, type in the IP add of the PC where the printer is installed, Port Name can be any name but try the Shared Name of the Printer, Next and follow all other instructions. Hope this works for you and pls post again how things turn up. Kind regards.
Posted on May 22, 2007
HP LaserJet M425dn MFP 79 Service Error
How To Troubleshoot HP 79 Error?
This is a fairly found as a common HP printers error which is usually caused by malformed PostScript documents in the HP printer. According to the study by a HP error 79 technical support professional team experts, printer shows a "79 Service Error" on the LCD display. HP service error 79 is a considered as a quite generic issue which is found on the HP LaserJet printer while working. Most of us face this same issue unexpectedly. But there are ways to get over with it:
What you need to have?
- Internet access.
-Admin account for the computers
Steps to resolve this HP error code 79
    ?In the very first step, you are needed to switch on the LaserJet Pro 400 printer.
    ?Ensure that the printer is properly connected to the internet. Users should be able to have a strong
    ?Ethernet cable connection running from the device to their modem or may even require to switch or a router.
    ?Now in the M401dn control panel/display section, click on the "Network" icon first.
    ?As per as study by HP error 79 tech support is concerned by a HP error 79 tech support technicians, verification of the IP address on the printer machine is necessary. Well, if it shows 192.168., then it clearly signifies that you are well connected to your home network. Else, a small check is needed to receive a symbol like 169.....
    ?Now step back to the home display section and then click on the "Settings" icon.
    ?Choose an updated LaserJet printer and then perform a check for all the firmware updates to ensure about all the latest updates.
    ?Continue the process by choosing a proper update and then click on the download and install button
    Fix your HP issues anytime with our HP professionals
    We deliver the best-in-class HP customer support service solutions for HP users across the world equipped with top-notch HP printer support solutions by applying the latest technologies to match users' need. Our HP printer support Toll-free 1-800-213-8289 number is all-time accessible for users across the world at our toll-free calling contact details to fix various critical types of HP printer problems affecting the performance of your HP printer. Prices are extremely feasible in nature.
Sep 16, 2013 | HP LaserJet Pro 400 MFP M425dn
I have an HP Laserjet P2035N that worked just fine until I moved it from home to my office. When I hooked it up to my laptop, which it has been before, it said the printer was offline. I've tried...
network printer is connected to check network connection. (cable, plug, etc.), if everything is ok not a problem to the network printer port on ferl can happen and if it is installed USB port, possibly connected to a another USB port
May 25, 2011 | HP P2035N LaserJet Monochrome Printer
The printer (hp laserjet p2015) appears offline
Press and hol the green 'go' button until the lights flash, (about 4-5 seconds) and release the button,
Wait for the config pages to print out, and then check your network configuration, i.p address, Subnet mask and gateway.
If no network page prints out, you might have a dead Network Interface in the printer.
May 10, 2010 | HP LaserJet P2015dn Printer
HP Laser Jet 4700 network card
HP LaserJet 4700 printer comes with inbuilt network card so you don't need to install another network card. If you want to but network card for your PC then go for 100/1000 Mbps network card.
Regards
Ashly
Feb 03, 2010 | HP LaserJet 4700 Printer
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 13, 2009 | HP PhotoSmart 1215 InkJet Printer
Computer can't find printer
Your using an Ethernet cable and your not on a network. You most likely need a USB cable, or connect the computer and printer together with a router. How are you accessing the internet from home?
Nov 19, 2008 | HP Laserjet 2605 Printer
Hp laserjet 1000 series problem
Time to clear some space on your hard drive. That's where virtual memory is paged to and from. Delete some files you don't need, and run defrag. Then your operating system will have more room to buffer the pages to the printer.
Sep 11, 2008 | HP LaserJet 1000 Printer
How do I set up a home network without internet?
Hi
By default, your wireless connection for your 2wire 1000HW is enabled.Assuming that everything is installed properly in your laptop ie wireless cards etc. than you can view your wireless connection using Dell Wireless connection tool and HP wireless tool. Your know its your network when it says 2wirexxxx {x=combined numbers}. To locate the built-in, 10-digit wireless encryption key for your system, please look at the bottom of the product [2wire] near the bar code label - looks like this : [xxxxxxxxxx].
If you want to access the 2wire Graphic Unit Interface ,you can access it by opening your browser and on your address bar type in homeportal- assuming you are able to connect to your 2wire wirelessly. You can view your network and change you wireless settings. This may also help you :
http://shastademo.2wire.com/rgw3-3/rgw/3-3/homeportal/network/wireless_settings.html
To connect your printer you must have a Print Server [ dep[ends on what model of laserjet you are using } and connected to your printer. Again you will need the encryption key to get it running. You must share your printer on each laptop by going to control panel and share it . In there you willl have the chance to change and modify the settings. You can also use the Windows File and Sharing Wizard. to get it both running.
Hope that would help you a bit. Pls feel free to post your questions in Fixya for further assistance.
Wish you all the best.
Cheers.
Jun 11, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
133 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
