Question about Jamo SUB300BA SUB 300 Powered Subwoofer Subwoofer
Jamo Sub300. No power. No lights
Replaced the blown fuse (230V 800mA). Box shows no life what so ever.
Could not find the wiring diagram to check the power supply unit.
  • kushanthad Jan 05, 2009
    Hi Thanks for the post. The box has no warranty as it's bought overseas. Checked with the dealer here and they confirmed it has no warranty.
    Yes. It's definitely looks like a power supply issue. problem is I dont have a wiring diagram to check.
    It has only 2 leads, no ground.
  • Anonymous Jan 12, 2009
    sme problm
  • 73 Answers
Well it would void the warrantee, but you can take the back panel off and the power supply will only have two leads (3 if grounded) in from the plug, and out to the crossover. It sounds as if you are correct that the power supply is bad.
Posted on Jan 05, 2009
  • charles durando Jan 05, 2009
    so if you have the back panel off, and the unit plugged in, you will be able to read 115 or so volts right at the solder points. then those wires will go into the power supply. test them where they go in, and where they go out and give me a voltage. do not worry about positive and negative, the meter will just give a -115 if its backwards. Smell the unit, usually you can smell a burnt smell if its blown.
Where is the license plate light fuse on 2003 chevy impala?
2000-2005 Chevrolet Impala Interior Fuse Check - 2003 ...
The video above shows how to check for blown fuses in the interior fuse box of your2003 Chevrolet Impala and where the fuse panel diagram is located.
Replace a Fuse: 2000-2005 Chevrolet Impala - 2003 ...
The video above shows how to check and change blown fuses in the engine bay of your2003 Chevrolet Impala in addition to where the fuse box diagram is ..
Dec 16, 2015 | 2003 Chevrolet Impala
Which fuse in the fuse box is for the power windows
Check fuses on panel, then check all connectors, check for kinked or frayed wire, then lastly, the circuit board for your panel! Not an easy task as you are checking for continuity between connections. If its the circuit board on your arm rest I would suggest a junk yard for a known good operating board. Make sure they have some type of guarantee as these are expensive new! Hope this helps Interior Fuse Box Location 2003 2009 Lexus GX470 2007 Lexus GX470 4 7L V8
The video above shows how to replace blown fuses in the interior fuse box of your 2007 Lexus GX470 in addition to the fuse panel diagram location. Electrical components such as your map light, radio, heated seats, high beams, power windows all have fuses and if they suddenly stop working, chances are you have a fuse that has blown out. If your GX470 is experiencing electrical problems, you should always check the fuses first, because they are relatively easy to check and cheap to change. Some Lexuss have multiple interior fuse boxes including in the trunk - the video above will show you where the interior fuse box of your 2007 GX470 is located. If your GX470 has many options like a sunroof, navigation, heated seats, etc, the more fuses it has. Some components may have multiple fuses, so make sure you check all of the fuses that are linked to the component in question.
If you need to replace a blown fuse in your GX470, make sure you replace it with one that has the same amperage as the blown fuse. If checking and replacing the fuse for the component in question doesn't work, we recommend seeking assistance from a trusted professional mechanic. They should be able to figure out if the component needs to be replaced or if there is a short or some other problem with your GX470.
Jun 05, 2015 | 1999 Lexus LX470
95 Dodge Dakota headlights, taillights dash lights suddenly went out. Have turn signals and flashers, no brake lights. Replace 15 amp fuse under dash that was blown nothing, replaced headlight switch
Did you check for voltage at the 50 amp fuse circuit. Even if the fuse is good if no voltage on the fuse circuit, the circuit is still dead. There is a light green wire that carries voltage from headlamp switch to dimmer, is that wire hot with headlamp switch on?
There are wiring diagrams for free, just about everywhere, if you don't have one. Autozone .com has free wiring diagrams on vehicle repair guides link. You have to register your vehicle, year--make--model, all that good stuff. It's free.
Dec 15, 2014 | 1995 Dodge Dakota
I hooked my battery backwards now my 95 GMC won't run no fuel no spark what's can it be
Bad DOG! Break out the checkbook, you may have blown the computer. Need to start there. Not sure if there is reverse polarity diode protection or not. Have it checked. Even at a scrap yard they won't be cheap.
Apr 15, 2014 | Cars & Trucks
Hi, I stupidly plugged my Pioneer DJM 500 mixer
You could have quite easily have blown something internal.
Sep 03, 2013 | Pioneer DJm500 Professional DJ Mixer...
check for 230v not 110 (on line to ground). SO checking L1 and L2 should show 230 v if not you have a fault in the timer or the breaker is toast. depending on the timer you can clean the points
Jun 30, 2017 | Pool & Spa
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me receiver is onkyo tx-sr 608
thank you
Jan 08, 2011 | Jamo SUB300BA SUB 300 Powered Subwoofer...
I have a 2005 Harley Sportster. I replaced the battery, turned the key and got nothing. front light is on. Checked fuses, 2nd fuse in first row was blown. replaced fuse, as soon as it touched contacts it...
Harley Davidson Wiring Diagrams and Schematics
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and connect it to the power side of the, circuit breaker or the blown fuse receiver, start by tracking the out bound wire towards the ignition switch and beyond if necessary, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website above. Good luck and have nice day.
Aug 23, 2010 | 2005 Harley Davidson XL 883C Sportster...
Jamo i300 dies after powercut
If its out of warranty you might as well open it up , and if your lucky it might only be a fuse to replace , if it is fused inside it will probably have blown before it could do any damage to circiuts . hope this helps
May 25, 2009 | Jamo A 102 HCS 5 System
Parking lights out
Check the Fuse Box inside for a Blown Fuse with a Really Good Flashlight. You will be able to see which one is Blown. Then Locate the Fuse Relay Box under the Hood and look at the Diagram inside the Cover and Locate the Illumination Relay, Replace this if you cannot Find a Blown Fuse. Please Rate My Response! Thanks!
Feb 06, 2009 | 2006 Scion xB
Jamo SUB300BA SUB 300 Powered Subwoofer Subwoofer Logo
1,406 people viewed this question
Top Jamo Audio Players & Recorders Experts
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
