Question about Microwave Ovens
The microwave switch sticking
Needs 20-50 presses to start
    Sergeant:
    Scholar:
  • 199 Answers
This happens after sometime in many machines.and a simple option is to replace the switch and the lower pad u can get the required parts at www.repairclinic.com
Posted on Jan 05, 2009
Microwave does not work
Need more information, like brand and model number. Also, does the inside cavity light go out when you close the door? If not, your problem is probably a bad door switch. If it DOES go out, but the microwave doesn't do anything when you press START, then you may have a bad keypad, control board, or it may still be a bad door switch (a different door switch - there are 3 or 4 door switches in most (all?) microwave ovens). Probably need to have a professional microwave repairman look at it.
Oct 17, 2014 | Microwave Ovens
Hi, My Bosch built in microwave won't start when I close the door unless I slam it. I suspect the switch. Think so? Can I get at ithe switch to replace without removing the whole unit from the
You will need to remove microwave to access casing, remove casing and check door micro-switch. The switch activator will need adjusting to enable door interlock to activate.
Sep 29, 2014 | Bosch 500 HMB5050 Microwave Oven
Microwave will not run when i press start
Not sure which relay switch you refer to but there is a switch that tells the unit the door is closed, that is your problem.
Nov 28, 2011 | Frigidaire FMV156DC Microwave Oven
When I press start on my sharp R-305K microwave nothing happing,
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 24, 2011 | Sharp R305KS Microwave Oven
Switching off the sound of my Samsung Microwave
1 Press the Sound button. The display shows "ON".
("START" will flash)
2 Press the Sound button to turn the volume off. The display shows:
"OFF".("START" will flash)
3 Press Start. The display returns to the time of day.
Lastly, you can find a copy of the manual here:
http://downloadcenter.samsung.com/content/UM/200507/20050727140356453_DE68-01945A[GB].pdf
Sep 01, 2009 | Samsung MW1030WA Microwave Oven
Turns on by itself and turntable does not rotate
You may have a control board issue. Thank God for safety switches.
This is a problem that an integrated circuit tech. can repair, but it may be costly.
Decide how much you want to put into this oven vs. buying a new one.
Contact me once you decide and I can help you find a service center.
Thank you,
Dave E. (Illeagle)
May 30, 2008 | Sanyo EM-S8000 Microwave Oven
Fan started running and will not stop when off button is pushed
Hi , the door lock switch are stuck./ the contact switch are not stick together need to replace new.
Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
