Question about Gem Sound GemSound PA-585 2-Channel Amplifier
I have a gemsound surround sound amplifier. what sound transistors does it take, de ones on de amplifier is d998 and b778, is it de correct transistors
It,s a surround sound amplifier av 316.i replaced transistors but de sound is very scratchy.
2 Suggested Answers
  • 113 Answers
SOURCE: gem sound exa-3950
check the rca's for a short
Posted on Jul 04, 2009
Gemsound pa 1005 exa keeps shutting off
I Think that something like a transistor is getting hot and then shutting down. Exploring inside might solve the problem of what's getting really hot. You could even get some Servisol Freeze Spray, and wait for it to go off then spray it on the suspected part. That will cool it down and it should start up again. If it does come on, that part will have to be replaced.
Jun 28, 2012 | Gem Sound GemSound PA-585 2-Channel...
Replacement parts needed for Thump amp TA2001
the part numers you need are 2sb778 and 2sd998. you can probably get them at pacparts.com or any local electronics parts supplier.
Mar 03, 2010 | Thump TA2001 Car Audio Amplifier
Gemsound xp-550
A diode/rectifer or voltage stabliser, or leaky capacitor in the power supply.
Also the main transistors in the power amp or if it has an output IC - that!
If you can in anyway disconnect the power supply section from the amp circuit, you can isolate which part is faulty. For if it blows when disconnected from the power amp, you know it's just the power supply that's gone. And if it does not blow - then it's the amp!
Aug 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Gem sound exa 3950 amp
Hi...
If it's a straight-up power switch then it will need to be replaced if it works off a relay then the relay is gone.
website
http://www.gemsound.com/contact.html#
Mar 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Manual
Contact Gemsound thru their email.
Sep 04, 2008 | Gem Sound GemSound PA-585 2-Channel...
I have a TEAC AG-H300MKIII which i purchased last May 2007. It has been working without problem for a year and now i find that it seems to have no power, it simply will not switch on. I have changed the...
Your output transistors have blown causing the internal thermal fuse in the power supply to fail as well, if you get time to see both output chips models B778 / D998 on the heatsink they need replacing, the thermal fuse can be bypassed by a qualified technician.
Jun 29, 2008 | Audio Players & Recorders
Panasonic sa ht530
REPLACE RSN IC(SOUND AMPLIFIER THEN CHECK AND REPLACE 2 -3 SMALL TRANSISTORS TWO 2SC3199 AND ONE 2SD592 THEY RE ON THE AMPLIFIER BOARD,EVEN WHEN RSN IC IS REMOVED SHOULD NOT SHOW F61 AFTER YOU'VE REPLACED THOSE TRANSISTORS
Mar 21, 2008 | Panasonic SC-HT730 System
Gem Sound GemSound PA-585 2-Channel Amplifier Logo
Top Gem Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
brian williams
Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
