Question about ViewSonic VA2226W LCD Monitor
White dspaly full white display
If the converter goes out does the tv not do anything no screen light uponly red standby light?
if your question is that if cable or sat converter goes off for any reason , will your tv display a black screen , then the answer is yes , without an input most all tv sets will display the opposite of full white , this being full black , also any on screen displays might not work as well (no video to sync too)
Jan 10, 2017 | Televison & Video
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Benq a53
press f8 function key and boot the machine to safe mode. if the screen is ok. try to remove and reinstall your display driver.
May 13, 2013 | BenQ Joybook A53 Notebook
No picture. Screen white
check the leads to your monitor. there could be loss of video input. However if there is no display indication then there is a failure of the video processing / video drive/ display drive of your monitor.
Normally you will need to replace the full board bbut check out the power and look for any discrete failures hoping your get lucky.
Good day
Jul 12, 2010 | Soundstorm SSV7HRM 7 in. Car Monitor
My N-6233 displays white screen when i switch on
i think your phone memory is full just re-flash program or connection of ic display was broken - re hot by air hot gun if you dont have bring it to service store
Aug 14, 2009 | Nokia 6233 Cellular Phone
Only black and white
try changing to another component video input. I see black and white on my tv for instance on "video 2". But when I switch to video 3 its full color
Dec 29, 2007 | Microsoft Xbox 360 Console
My n70 had white display pls help me sir
full charge the set..it might show the display then..but after some hours it might become white again..i am also searching for a solution of this problem!
Sep 03, 2007 | Nokia N70 Cellular Phone
Sony w550i
Its software problum(100%) Make it full flash. will be ok.
Feb 01, 2007 | Sony Ericsson Mobile Bluetooth Car Kit...
ViewSonic VA2226W  LCD Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
