Question about Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor
My monitor appears to have no power. No front lights though the power cable is good.
This monitor went from working to not working. At first I thought the fuse in the plug had gone but it's fine. Not sure if there is a fuse on the input internally. Reluctant to just play with it as the PSU is internal to the device so I'm potentially working with 240v not just 6/9/12v. Pretty sure it's not just an inverter/backlight problem as the front panel lights usually show something in that situation even if not connected to a PC
  • Dell Master
  • 1,684 Answers
Hello Dave,
Check the power light, if it is faintly blinking then this link should help you get it going. That model is well known to have a problem on the control board that causes the monitor to not power up right.
http://www.instructables.com/id/FREE-17%22-LCD-Monitor---How-to-do-it%3f/
Posted on Nov 06, 2012
SOURCE: DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Posted on Nov 26, 2007
jemmyrash
  • 180 Answers
SOURCE: Samsung 192N suspect power supply problem
I'm sure it is power board failure that need repiar or replaced the defectieve parts of your LCD .
Posted on Apr 18, 2008
shaggyrat
  • 1224 Answers
SOURCE: problem with the samtron 45bn monitor
sounds like your video card went out simple check of this
if you have another computer that works hook it up to its computer if screen comes on it will be your video card in the comp now if the screen still doesnt work it will be the cable the pins in the end has some how bent or come loose this will require a service tech electrician to repair simple quick job
Posted on May 26, 2008
SOURCE: samsung 45bn
hi... there's a resolution problm with samtron45Bn with win xp.
Pl.help to fix this pblm.
Posted on May 27, 2008
jomama5509
  • 87 Answers
SOURCE: Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
Posted on Jun 17, 2008
Power went off no monitor is giving check cable error
If you're seeing a "Check Cable" message on the monitor - it's working. If this message appears, it means the monitor isn't receiving a signal from the computer. Cable could be loose, or video circuit has failed.
Nov 19, 2014 | Computers & Internet
Monitor was in standby mode, computer was on. Now it shows no signal and when we try using the menu button (2) it flashes white, black, red, green, blue then a teal color.
the monitor is not receiving a signal from the computer which is why the multi coloured bars are showing. Ensure the lead is connected and is connected to the correct port of your computer. If it is connected correctly then either your graphics card is faulty or the lead, or monitor is
Apr 03, 2011 | Computers & Internet
My screen just went black
Hello, if the Toshiba monitor went black: 1)if there is power from the monitor, check power cable and data cable 2)make sure that its properly connected to the computer 3)make sure computer is on and there is an activity from the computer 4)if the is sound from the computer try a known good monitor if that will work 5) try this Toshiba monitor to a working computer 6)try checking the monitor maybe the back light is busted get a flash light point it directly to the screen it self check if you can find something 7)if all is done bring monitor to a repair station if in warranty manufacturer Thank you for using Fixya
Mar 06, 2011 | Toshiba Computers & Internet
VA902b Viewsonic monitor just went black this morning while working. Tried updating driver. Reboot. Does display during startup and goes black again. Monitor problem or hardware? I have 2 monitors.
The best thing to do to isolate the problem is to connect the problem monitor into a known working CPU. If the same problem occur, then the problem is the monitor. You may need to check if the power light (LED) is blinking or no light at all.
If there's no light, you may start replacing the power cable if the cable is detachable. But if it's built-in to the monitor, then send it to the authorized repair shop. They need to check if the panel is shot.
Thank you and good luck!
Nov 01, 2010 | ViewSonic VA902b 19" Monitor
It doesn't send a signal to the monitor
Initially check the monitor whether it is working good you can check it by removing the monitor cable from the system when you remove cable you will able to see question mark in case of crt monitor this ensures your monitor is working good.
when you power the system whether processor works if the processor works means you can conclude that the problem is with the ram or the video parts of mother board.
Clear the dust in the ram slot and reinsert the ram
Then remove the cmos battery of the system and reset the bios settings.
Check whether the power cables are correct.
then power on the system if you receive display the problem is solved.
If the display does not appear check by replacing the new ram then giving motherboard to service centre
Mar 10, 2010 | Mercury P4VM800M7 Motherboard
My DELL flatcreen just went blank and is now flashing yellow light, won't turn on
Check and make sure your connections on the back of the PC are snug...and make sure you have a good connection at the back of the monitor.
Flashing light...is loss of signal.
Good Luck,
Mike
Nov 06, 2009 | Dell 1702FP UltraSharp 17" TFT LCD...
Monitor wont turn on, just green flashing light.
double check that all yor connections are tight. Open your PC case (unplug it) and ensure that all your fans are clean. It appears that your problem is due to loose cable connections, but this may be a good time to do some computer spring cleaning.
Apr 29, 2008 | Acer AL1916B 19" LCD Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor Logo
114 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
