Question about Acer Aspire 5315 Notebook
Left shift key wont go back on
My left shift key wouldnt press down so i carefully took it off now i cant get it back on...also a small piece of blue plastic was snapped in side
    Guru:
  • 859 Answers
Given that replacement keyboards are not all that horrendously expensive you could actually replace the keyboard if it comes to it eventually.
However, what we did in the old days when replacing keys with worn out lettering was hold a soldering iron on the metal finger the keytop attaches to until the metal of the finger is very hot. Hot enough to push the keytop back on. While you push the keytop down onto the metal finger hold and press firmly for about 1 minute and then release. That should meld the two together if its going to happen at all. Leave it untouched for at least 30 minutes to ensure a firm bond.
This doesn't mean this will be an end all solution to your problem.
Because you mention the broken plastic piece, this mean this keytop may come loose or off again at some time in the future.
If you have tried and used super glue already be prepared for a smoke stench that will come off while you hold the soldering iron on the key finger. Burning super glue is how CSI techs reveal finger prints. That doesn't mean its very safe to breath. So, take some ventilation precautions while you do this. Essentially, do not breath the smoke directly, it will rise quicly on its own until its burned off.
Best of luck,
Worldvet
Posted on Jan 05, 2009
How do I use the blue coloured symbols below my number keys?
when keys have 2 options on them you either hold down the shift button to change keys or the FN blue button to use the blue symbols ( to sum up,hold FN in and press a blue symbol,hold shift in and press a key with 2 options on it ) FN button is usualy bottom left of keyboard
May 30, 2015 | HP Computers & Internet
How to fix a broken key
Pry it off carefully with a small flat piece of plastic or metal. Look for some debris underneath. There should also be some mechanism, such as a small spring or metal "X" to push the key back up, it may not be connected or snapped in properly.
Jan 31, 2014 | ASUS X53SD-RS51 Intel Core i5-2450M,...
Keyboard Not Working
Laptop keyboards are a little more delicate than keyboards used in desktop computers. Hence they face more problems. Normally, they are replaced when they render defective. However, most of these keyboard issues can be taken care of or even prevented by regular cleaning. Common issues like, keys not working on your keyboard, having to press keys firmly to get the output or any keyboard typing issues, can easily be handled at home.
Sometimes you may find certain keys of your laptop's keyboard to not be working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result. You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication. Therefore you are supposed to maintain your laptop's keyboard by cleaning and lubricating it regularly.
Troubleshooting Steps Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. To start with, take out each key. Use a small screwdriver to carefully pry each key by making it loose. As they become loose, keys will simply pop off. Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers. Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water. Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces. Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone. This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely. The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly. To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat. Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry. Once you have cleaned and lubricated all the parts, carefully reassemble the keyboard. Begin with placing all rubber components on the keyboard. Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it. The complete process will take you a maximum of 2 hours. Cleaning and lubricating the keyboard in the above prescribed manner once a year, can prevent many such situations. Pressing the 'Function' key along with the 'Num lock' key (Fn + Numlock) or press the 'Function' Key along with the 'Shift' and 'Num Lock' key (Fn +Shift + NumLock). This will disable the lock and consequently solve your problem.
This was all about solving your laptop keyboard problems that you can try out yourself. After trying all the above given options, if you still find the keyboard still not working, you will have to take your laptop to a service center to get it repaired
Hope this helps.
Jan 10, 2013 | Sony VAIO Computers & Internet
Cant figure out how to get it off the little blue symbols
Either the "blue" coloured 'FN' is _stuck_ in the "down" position, or you have accidentally activated the "Sticky Keys" Windows "accessibility" tool.
With "Sticky Keys", you press keys just _one_ at a time, e.g., CTRL then ALT then DELETE instead of pressing multiple keys (SHIFT and '8') at the same time.
Restart, in order to turn-off "Sticky Keys".
Or, "exercise" the 'FN' key, until it "unsticks" itself.
May 07, 2010 | HP Pavilion dv4000/dv4200 Series Keyboard
Fault in Central Locking
The barrel is easy to remove and based on replacing mine(the same problem with someone elses help) when a rat forced it with a screwdriver one night but failed except to damage 3 of my locks.Open the door and by the inside area of the door handle end theres a small torx screw, undo it a few turns and the smaller piece of the handle will be loose to the touch, turn a little more(screw wont come out fully) and remove the barrel in one piece.I stripped mine and using a breakers yard barrel i took the numbered little key slots inside and put them in the same code as mine to use the origional key.All key slots are numbered so write down your sequence when stripping down it's easy.
Dec 22, 2009 | 2000 Volkswagen Passat 4Motion
Gear shift stuck
I am having the same problem with my 05 Altima. For a temporary rememdy we took stuck a key down into the release hole in front of the gear shift. There may be a little cover over the hole, but if you take it off and stick something in it, it will release the shifter.
Aug 12, 2009 | 2006 Nissan Altima
Key doesnt turn
dose your car have a key removal lock ? a lock you have to press befor you can remove the key ?
there is a shift over ride by your shifter. between/around the shifter and the radio (closer to the sifter) there is a small round plastic cover you can remove with a small flat head screw driver. remove this. you will a key or the screw driver and insert it into, what looks like a key hole for your car and turn/press (sorry for being vauge GMC's change year to year) this should allow you to move the shifter into park. make sure the car is off or at lest you have the E-brake on as well as your peddle brakes.
May 30, 2009 | 1998 Oldsmobile Intrigue
Alternate keys on HP Keyboard
Activate:
Ctrl + fn + right shift key
Deactivate:
Ctrl + fn + right shift key twice
so hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
Jun 09, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Gateway Keyboard left shift key adds a pipe character
The driver will not fix the problem, as this is a mechanical problem. I had the same problem and was able to fix it. Instructions with pictures can be found at: http://lotus.kick-***.net/keyboard
Here are the instructions without the pictures:
I had a problem with my Gateway keyboard where whenver I pressed the left shift key, it type a pipe | (verticle line) character. This is the same character that is above the back slash character . I searched the internet and people were suggesting reloading drivers and apparently Gateway was suggesting a destructive reload of the hard drive. That's absolutely rediculous.
After some research, I determined that on some European style keyboards, the backslash/pipe key is between the left shift and the "Z" key. So, I removed the left shift key to experiment. The key simply pops off by sticking a screwdriver under it. (It is not necessary for you to do this).
When I used a little screwdriver to press on the center of the plastic (red arrow) I would get a proper shift key. However, when I pressed to the right (green arrow), I would get the backslash character. If I pushed at the red and green arrow together, I would get the pipe character.
Ah-hah! I determined the problem. The inside of the keyboard is a "universal" type and can be used with U.S. or Europeon keyboard layouts. For whatever reason, the left shift key was hitting both dots under the key. (The dots are visible in the pictures below.)
To resolve the problem, it is necessary to disassemble the keyboard. On the bottom of the keyboard is a bunch of screws. Remove all of the screws. If you have any rubber feet, there is probably screws under the rubber feet. The feet are just held on by sticky taope, so they peel right off.
Once all of the screws are removed the top and bottom halves seperate easily. The circuits stay in the bottom half of the keyboard, so set the top half of the keyboard to the side. The red arrow marks where the left shift key presses down.
Pull back the top layer and you will see the flexible circuits. These are also made up of multiple layers. When a key is pressed it pushes these layers together to complete the switch circuit. The red arrow marks the shift key. The green arrow marks the backslahs/pipe key for European style keyboards. The blue arrow is yet another key that is not used on U.S. keyboards.
Pull back the first layer of the switch circuit to expose the space between the circuit layers.
Place a small piece of electrical tape on the extra backslash/pipe circuit connection as marked by the red arrow.
Now simply reassemble the keyboard and that weird pipe character will never accidentally show up again.
Mar 08, 2008 | Gateway 2520915 Keyboard
Gateway keyboard shift key creating special characters when used
This is a mechanical problem. I had the same problem and was able to fix it. Instructions with pictures can be found at: http://www.sportmachines.com/keyboard/
Jan 30, 2008 | Gateway 2520915 Keyboard
Acer Aspire 5315 Notebook Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
