Question about GE 36 in. Profile JP960 Electric Cooktop
I have a GE Profile JP960 electric cooktop. The heat output from the large burner will increase over time. It still works, but gets to hot.
fridgetech
  • 473 Answers
SOURCE: ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Posted on Oct 26, 2007
  • 1214 Answers
SOURCE: GE profile performance electric cook
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Posted on Jan 23, 2009
appldoctom
  • 311 Answers
SOURCE: Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Posted on Jan 30, 2009
SOURCE: Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
Posted on May 29, 2009
Controlfrk
  • 304 Answers
SOURCE: Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Posted on Aug 31, 2009
Hot surface light stays on on GE Profile Cooktop model JP989 and On does not light for left burners. This is only happening on left burners. Left front burner goes to high with any setting on the switch...
You could have a shorted burner, if it is not then you may have gotten a bad part.
always unplug electricity before attempting to repair on any electrical appliance
Aug 17, 2017 | GE 30 in. Profile JP989 Electric Cooktop
My ge profile keeps popping and tripping the breaker everytime i turn it on
I would call in an electrician, this is something that could burn your house down
Oct 19, 2010 | GE 36 in. Profile JP960 Electric Cooktop
Pouring out smoke when using self clean feature -
Seems like you found out the hard way what I wrote about in this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 28, 2010 | GE 36 in. Profile JP960 Electric Cooktop
Can a novice replace the elements on a GE PROFILE electic cooktop JP960
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Feb 21, 2010 | GE 36 in. Profile JP960 Electric Cooktop
F113
I have the same problem. I had a repair man here and he said the main powder logic board ( WB23T10014) was the problem, it would cost $757 to fix. I ordered the board for $230 and installed it myself but still have the F113 problem.
Jan 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Cooktop burner cuts off and on. does not maintain heat properly
bad thermal sensor in the element, do they all do it or just one?
if it is just one then replace the element if it is all the replace main board, this can be pricy in some models check the users manual for waranty info some brands/models cover such items for several years
Sep 19, 2009 | GE 36 in. Profile JP960 Electric Cooktop
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
GE profile performance electric cook top is not producing enough heat in the front burners.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
Burners of electric cooktop not getting red hot
Hello
Welcome,
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
GE 36 in. Profile JP960 Electric Cooktop Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
