Question about Nortel Lands Phones
How do I set up music (radio from my pc) using headphones on my Nortel Networks phone, model #NTDU91? Is there a feature for that? Thank you
Nortel Networks phone NTDU91
    Scholar:
  • 277 Answers
You should call in your local vendor and have this done.
They will need to install a jack that matches your headphone jack and punch it down to a certain pair on the phone system, they will also need to go into configuration programming and set the feature.
Config password and knowledge of wiring and programming required. Note you need to purchase a license to "re-broadcast" music on phone systems, paging equipment etc.
Canada license - http://www.socan.ca/licensees/faq-licensing
USA license - http://www.ascap.com/licensing/
Penalties:
The Penalties
Under U.S.C. TITLE 17, the law allows copyright owners to receive as damages for infringement between $500 and $100,000 for each work infringed
Posted on Nov 06, 2012
SOURCE: Changing the time on a Nortel networks phone
Feature **time (type out time on the dialpad.)
Posted on Apr 17, 2008
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Posted on Mar 12, 2009
  • 60 Answers
SOURCE: How do you disable the speakerphone on a Nortel
That needs to be set in the administrative side on the system. The set configuration. Do you have access to system programming?
Posted on Aug 01, 2009
  • 18 Answers
SOURCE: I have a nortel norstar M7310 phone. we have used
Feature #85 (Note #FEATURE CODE deactivates that feature code)
Posted on Nov 17, 2009
  • 52 Answers
SOURCE: Change Time
THe older norstar systems you had to go into programming to change time and on the newer systems press feature * time on your phone and follow the prompts. On the older systems go in to programming press feature ** 266344 (config) then pswd 23646 (admin) on your key pad this gets you into programming press next until you get to change time. You need an overlay which can with your phone system manual. If need more info please ask agian hope this helps.
Posted on Jan 04, 2010
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
Jun 25, 2015 | Nortel Networks T7316E Telephone Platinum...
How to stop the hold music from playing through the speaker constantly?
press [Feature] # 86
to turn off Background Music (as Nortel calls it).
F86 to turn on
F#86 to turn off
Sep 29, 2014 | NorStar M7324 Telephone
How do I get my phone to ring
Maybe you set the Do Not Disturb by mistake. press "feature #85"
or maybe you call forwarded it. press 'feature #4" or turn up the ringer 'feature *80'
Sep 22, 2014 | Nortel Networks T7316E Telephone Platinum...
How do I remove Denied in Admin from a Nortel phone handset t7208
It's not so much removing Denied in Admin as it is enabling whatever feature the user was trying to access at that set.
Which was... ?
Aug 11, 2014 | NorStar T7208 Corded Phone
How do you transfer a call on a Nortel t7208?
This is usually programmed as one of the 'soft' buttons down the right hand side of the device - subject to the programming of your phone / and the system.
Usually the T7208 is connected to the BCM range of PBX systems - in which case, to transfer a call, you'd use Feature 70. You could, of course, program this into one of the buttons yourself, so you only have to press one button to do so.
Hope this is of use to you. :)
Oct 29, 2013 | Nortel Lands Phones
How do you turn the music on with a nortel phone?
Try FEATURE 8 6 to turn on the music FEATURE # 8 6 is to shut it off
Have fun and enjoy your music...
Sep 14, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Changing names on Extensions
Press "Feature **ADMIN", go to NAMES, Then go to Sets, and from their its just like texting
Aug 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Feature 86 (background music)
The music does not come from the phone system . What ever you are using for your music like a radio , cd player mp3 that is where you change it .
Mar 05, 2008 | NorStar M7324 Telephone
Lands Phones Logo
153 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
