Question about Generac GP5500
I recently purchased a generac 5500E generator. Starts and runs ok for about 10 minutes then the carborator starts oscillating like it is running out of fuel then it shuts down. Will not restart immediately. Fuel full. Engine oil full. Moderate electrical load.
5 Suggested Answers
  • 27 Answers
SOURCE: Suddenly in power outage and engine starts auto., NO inside power
DO U HAV POWER FROM GEN ?
Posted on Sep 04, 2009
Testimonial: "Thank you for taking the time to respond. Much appreciated."
  • 905 Answers
SOURCE: Small 7kw Generac has always sounded rough over
If the generator is out of warranty, you can try spraying a short shot of ether into the intake of the generator as it is running rough. If the engine smoothes out for a few seconds, and returns back to original state, then it is likely running lean. Check the gas regulator (this is LP or natural gas I am assuming since it is standby), the vent may be clogged on the bottom of it.
Posted on Jun 12, 2010
SOURCE: Generac generator will start, run for a moment and
Its the Oil sensor just pack the oil sensor wires together with a smal screw and bolt and try starting if it starts your problem is the oil sensor they tend to go bad I have run through several myself . To avoid hassles I now have overidden the sensor but I check the oil level everytime I need to use the generator
Posted on Sep 03, 2010
ftw1952
  • 10319 Answers
SOURCE: I have a Generac generator
clean the orfice in the output valve and try again
Posted on Apr 13, 2011
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Generac Generator won't stay running
fuel problem, the float in the carborator is stuck, if you tap on the carborator bowl it will probably get freed up.if not take the bowl off and spray the insides with carb. cleaner.
Apr 11, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
Generac GP5500 Logo
67 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
Matt Olenzek
Matt Olenzek
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
