Question about Hardware & Accessories
Trying to reset timer - Hardware & Accessories
  • 5,089 Answers
When i unplug the timer then reset a new time schedule and plug timer back into wall my timer sets to 88:88. whats am i doing wrong? this timer worked brilliantly until i reset and plugged it back in.
Open following link to identify timer and read instructions:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Timers go bad for many unprovoked reasons.
Check outlet with circuit analyzer.
This timer has 1 year limited warranty.
Extended warranty: If timer is defective, then buy new one from Target or Lowes, and return defective timer in new package.
To review:
Replace AA battery if this model has a battery carriage. Otherwise timer has internal rechargeable battery.
Press reset button with paper clip for a few seconds.
88:88-88 will flash on screen momentarily, and then 12:00 am will display. Timer is ready for programming.
If 88:88-88 does not roll over into the 12:00 am display, try resetting again.
If timer will not hold new programming, and keeps resetting, then see if reset button is stuck.
If timer does not reset and re-program correctly, then timer has gone bad.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 23, 2011 | Woods Industries 59377 Indoor Digital...
How do you delete a program Intermatic hb88rc
Try removing battery, and then reprogram timer.
Some timers are reset when battery is removed.
Newer digital timers keep programs in memory when battery is removed, but in that case the instruction manual shows steps for resetting timer and deleting programs.
The HB88RC manual does not show steps for deleting programs or resetting timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
Sep 21, 2011 | Intermatic HB88RC - 7-Day Programmable...
I have a timer TX12674T im trying to reset the time by holding time and hour the screen resets itself to 12:00 any combination will rest the screen. what to do?
Timer is not identified.
My files, and web search do not show TX12674T timer, Aug 2011.
1) Add a comment with in-focus photo of your timer posted on flickr for possible identification.
2) I don't have repair for defective timer: What does your instruction manual say? Did timer work before and stop working? Are you using timer for correct Load? Try timer on different outlet and with different Load. Test outlet with circuit analyzer. Timers usually come with 1 year limited warranty.
3) Maybe you have TX12874X. This timer is reset by holding down Hour and Minute button.
4) Open following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Aug 13, 2011 | Timex EASY TO SET TIMER BY TIMEX
Sunset sunrise doesn't seem to work anymore
If digital timer does not function as before, try resetting timer and then re-program.
If timer has battery, then change battery and reset timer.
If reset does not restore functionality, then timer has gone bad. Most in-wall timers have 1 year limited warranty.
Below are common 7-day timers, but there are many different brands:
You posted under Woods 7-day timer: except Woods timer does not astronomic dawn dusk function. Woods 7-day is same as Tork 7-day and GE 7-day, and they do not have astronomic function.
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Reset button is small round button.
Push in reset with toothpick or paper clip.
Then reprogram timer.
If you have Intermatic ST01C or EJ500 battery operated timer: Replace battery, then to reset timer: push-and-hold ON_OFF button, and then push reset button. Keep holding on-off button until display changes. Release on-off button and display will flash 12:00. Then reprogram timer.
If you have Utilitec astronomic timer, then press reset button and reprogram:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Aug 05, 2011 | Woods InWall 7 Day Digital Programmable...
I need to know how to reset the timer
If you reset ST01C timer using reset button, then all programs are lost, plus current time of day.
Generally this timer needs to be reset if error message appears and as last resort for troubleshooting problem. Timer does not need to be reset after battery goes bad, all you do is set current time of day, and then program remain inside timer indefinitely (or until timer is reset of goes bad)
If setting current time of day does not work, you use reset button.
For ez programming steps with illustrations:
http://waterheatertimer.org/ST01C-program.html
How to reset ST01C using reset button:
Push and hold ON-OFF button and then push reset button using toothpick or paperclip.
Release reset button but keep holding ON-OFF button until INIT displays.
Then release ON-OFF and 12:00 should be flashing.
If timer functionality does not restore, then try replacing timer battery.
If functionality will not restore, then timer is bad.
This timer does not need electric current for setting timer, so timer display is not dependent on circuit breaker.
If you have a different timer, then add a comment with in-focus photo of timer for possible identification. Most other timers do not require 2-button reset procedure.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
Apr 23, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a timer for a lamp outside it is making a loud buzzing sound even when turned off.Is there sometime that i can do to stop this?
You timer is buzzing.
Try changing light bulb > sometimes these timers malfunction when there is line interference.
Try resetting timer with reset button.
Some timers require holding down on-off button while pressing reset button.
Check your manual.
If you don't have a manual, open following link to help identify your timer and download manual.
http://waterheatertimer.org/Programmable.html
If resetting timer does not solve problem, you might need new timer.
Most timers have 1 year limited warranty.
New one can be purchased at local home center.
Add a comment for more free help.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 20, 2011 | Hardware & Accessories
Tried to reset the intermatic timer. But, the timer won't turn off
You posted under self-adjusting Intermatic, which I assume is ST01C
Add a comment if you have different timer.
I had the same problem resetting my ST01C because I was pushing reset button without holding down ON-OFF button.
But my timer is fairly new and hasn't malfunctioned.
A lot of folks write-in about ST01C that just doesn't work any more.
To reset timer: hold down ON-OFF button, and then use paper clip and push reset for full three seconds.
Release reset but keep holding ON-OFF.
Keep holding ON-OFF button until INIT shows on screen.
Release ON-OFF and wait for timer display to show.
If timer display doesn't restore, then change battery with new CR2.
People write in after changing battery and report timer never came back to life.
So these timers are hard to figure. ST01C has 1 year limited warranty.
To re-program timer for specific hours instead of dawn-dusk, there are clear steps on link below
Nov 28, 2010 | Intermatic & Self-Adjusting Wall Switch...
I have a digital wall timer that allows for settings over multiple days. Trued to reset it (remove a few memorized settings) by pushing 'reset'; but this had no effect. Do I need to press it for a longer...
You posted the question under ST01C timer.
This timer will clear all programs if you hold reset in for a few seconds until the screen starts blinking 12:00. The reset button is a small round button that you push with a paper clip.
The ST01C memory for current day can be cleared by removing battery for a couple minutes, but the day-to-day programming remains forever until timer is reset.
Each timer tends to follow the same pattern as described above when there is a small round reset that is pushed with a paper clip >> push, hold for a few seconds, timer resets.
Other timers have a larger button for Reset ... the timers with larger reset button usually require you to hold the clock button and reset button at the same time ... or some other button besides clock has to be pushed at same time with reset. You can try different combinations of buttons and hold both down for a few seconds.
If you reply to this response with your exact model and brand timer, I can look up the specifics for most timers
Oct 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How to reset the programming on timex lamp timer TX12694TA
For some Timex timers, press PROG and MODE at same time to reset timer.
Open following link for random Timex manuals:
Jul 14, 2010 | Hardware & Accessories
I keep pressing NEXT/ON/OFF and RESET to reset the
Review instructions:
Instructions say hold down Next ON/OFF > and push Reset > then release Reset > but keep holding down NEXT ON/OFF until screen flashes 12:00 >> after that, you release NEXT ON/OFF
If that doesn't work:
Timer functions are powered by battery, not by electric circuit, so your wiring is not cause of this problem.
Try removing battery for longer than 5 minutes.
This will reset time/date but not your programs >> the programs stay in the timer forever until reset.
Then try the reset procedure again as shown above.
If timer still doesn't reset:
EJ500 has a 1 year limited warranty.
You may need a new one.
Apr 09, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Hardware & Accessories Logo
15 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
