Question about Indesit W 123 Front Load Washer
Indesit w123 washing machine
My washing machine stopped working the other day and i cant really affored another one just yet. So please can you help. I was told that it is showing me a error code and all i have to do is fine out the code. When you reset the machine to start a new wash it fills briefly then empties, the light flashes 10 times then stops for a few seconds and lights flash 10 more times while the dail clicks round none stop. Please help, Thank you.
Hi had a similiar problem on a year old washing machine after 3 engineers later who 1..put in a new circuit board...did not work 2...put in a heating element ...did not work 3...techican engineer..put in a new motor and repalced air pressure switch...bingo did work if your drum is turning slowly and does not wash how very well you may find ur motor is getting worn out..a problem..?? b careful they r £90 so make sure its that b 4 u change it my machine started to fill then almost immedately emptied out..then tured off then i had the flashing lights hope this is some help to u
Posted on May 29, 2007
    President:
  • 1,294 Answers
Suggestion: The pipe behind your machine has to have a certain height (the machine drain pipe); it does not go directly into the drain at floor level. Check this out.
Posted on May 22, 2007
SOURCE:
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
Instructions
Here below instructions for Indesit W123 selected on title. This model has no dryer.
Washing machine
Jan 11, 2009 | Indesit W 123 Front Load Washer
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
Replace door rubber W123
how do I replace the door rubber on Indesit W123
Oct 26, 2008 | Indesit Washing Machines
Indesit w123
not really worth replacing timer as many problems can cause this
May 19, 2008 | Indesit W 123 Front Load Washer
W123 dispenser drawer keep melting
Hi there you can order the part from indesit and should not cost alot and yes it should withstand the temp check that if you are using the hot tap to the machine turn down the water thermostat as maybe too hot.
Thanks J
Feb 09, 2008 | Indesit W 123 Front Load Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
666 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
