Question about Exercise & Fitness
Loose flywheel on confidence cross trainer & bike
The flywheel has rocking movement can you tighten it up
SOURCE: lost instructions for Rober Black cross trainer
Hi, I have bought a second hand roger black silver cross trainer and I do not have any instructions, also the bolt that holds the front post together is missing and the tension dial does not seem to work can I adjust the tension in side the front post! Please can you help. Kind Regards Janet
Posted on Mar 20, 2009
  • 71 Answers
SOURCE: problems setting up bike trainer
put the bike in while the trainer is opened. tighten the bolts around the skewer. that should be straight forward... good luck
Posted on Jun 09, 2009
greenspan
  • 1734 Answers
SOURCE: Manual for Reebok REV-11101 Fusion Cross Trainer.
If anybody can get the fusion cross Reebok manual, these are the right guys
Posted on Jul 06, 2009
greenspan
  • 1734 Answers
SOURCE: instructions for reebok cross trainer 10101
Check here, they can get you any Reebok manual
Posted on Jul 23, 2009
SOURCE: instruction manual for olympus cross trainer
I cannot get the timer to work on the olympus sport ascent cross trainer.
Posted on Aug 19, 2009
I need a manual for confidence cross trainer and bike
Try Googling (confidence)(model)(manual) without parens.
May 16, 2017 | Exercise & Fitness
I need a left peedle for my confidence fitness 2 in 1 cross trainer bike please..
dont know if you got one but I needed a right pedal and it cost me 10gbp from the manufacturer all I had to do is ring them on 01527 598388 and it arrived within 24hrs I was very surprised. item number 23-pedal http://g-ec2.images-amazon.com/images/G/02/uk-sports/Team/B000QZ54MS._V358643820_pdf
Aug 01, 2013 | Confidence 2 In 1 Elliptical Cross Trainer...
When its running theres a rubbing noise comeing from the flywheel area
Pull the left case cover and take a look. Do you see any rubbing marks on the outside of the flywheel? Any marks on the inside of the cover? Any leaves or other trash at the flywheel? Start the bike with the cover removed. Is the rubbing sound still there? Is it actually coming from the flywheel or somewhere else? Turn the bike off. Lift the flywheel up and down then left and right. The flywheel should be rock solid. If movement is felt then you have a bad crankshaft bearing. Replace both crank bearings and crank seals. It would be a good idea to replace the sprocket shaft outside bearing if any movement is felt when trying to move that shaft. Replace the seal anyway.
Check the problem before riding again. Bad bearings may be letting the inside of the flywheel rub on other internal components. That is not a good thing.
A “very helpful” rating on this answer? Thanks!
Jul 02, 2009 | 2005 Yamaha DT 125 RE
Lost instructions for Rober Black cross trainer
Feb 01, 2009 | Exercise & Fitness
Problems setting up bike trainer
Jan 08, 2009 | F2 Forza F-2 Magnetic Bicycle Trainer Bike
NOISEY SCHWINN 430 ELLIPTICAL
Hi I'm Ryan, do you know where it is squeeking from? if you can find the squeek try 3 in 1 oil that should stop it.
Dec 14, 2008 | Schwinn 430 Elliptical Trainer
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
