I want to use my baxi bermuda gas fire just as a fire as having a combi boiler installed is it possible
  • Heating & Co... Master
  • 2,522 Answers
Yes a combi boiler has to be piped so they would cut off the pipes to your baxi and you can ues it as a gas fire only
Posted on Nov 07, 2012
  • mark Nov 07, 2012
    Cheers for the info, great help, daughters funds running low so changing to combi and using bermuda as just a fire will be great news for her
  • 2522 Answers
SOURCE: got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Posted on Feb 20, 2010
  • 120 Answers
SOURCE: how to light pilot light for baxi bermuda sp3
Go to this link.Bottom of page 15 on the manual
http://www.aroundtownflats.com/manuals/Boilers/Baxi/BAXI%20BERMUDA%20SP3%20GCNo.37-077-63.pdf
Basically it says (turn on the power first) Turn the knob to the the star/flame marking. Push the knob in, hold it for approximately 10 seconds. Release and check the small flame is lit. Now turn it to your desired heat setting.
Posted on Jul 21, 2010
  • 2522 Answers
SOURCE: Baxi Bermuda VP gas fire.
try cleanig the spark elctrode could be dirty use some steel wool carefully to clean it
Posted on Jul 25, 2010
  • 13 Answers
SOURCE: pilot light on baxi bermuda
Sometimes the thermostat wire (not sure of the technical name) gets oxidized and can't sense the heat (it's there as a safety measure so that when the pilot light goes out, the gas shuts off). If it isn't to hard to get to, sometimes you can use some aluminum foil to clean the wire so that it senses the heat of the pilot light flame. Make sure the main unit is off, and let the unit sit for awhile to make sure there is no residual gas hanging around. If this doesn't work, you might have to get a specialist out to replace that piece. Hope this helps.
Posted on Feb 17, 2011
  • 4736 Answers
SOURCE: baxi bermuda 50/6 inset 3 burner ignites but vry
Mark, it sounds like the pilot may be dirty and needs cleaning. A can of compressed air with a straw nozzle (like you clean your computer with) works well for doing this. Also, make sure that the inline ON/OFF gas valve, on the gas line going to the heater is fully OPEN.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 18, 2011
Boiler not running smoothly
needs tune up change filter and nozzle and check electrodes are clean with no build up and clean out chambers
Oct 10, 2016 | Heating & Cooling
Hiya. I have an old baxi boiler wm 38/RS . The pilot light is on but the boiler will not fire up . Can u help me
Rubbish!
Cleaning the jet is a job ONLY for a gas fitter as it involves disturbing both the case seals and the gas pipework. DON'T RISK YOUR SAFETY, besides which if the pilot wasn't powerful enough it would continually go out.
Check (if you're competant to do so) that there's 240vac across the gas valve solenoid connections. If so then the gas valve will need replacing by a GAS SAFE REGISTERED fitter.
FYV
Jan 18, 2013 | Combi Centre DX - Mango
Were can i get a mannual for a baxi bermuda 50/5inset back boiler fire
You can download one from there wed site baxi potterton wed site
Apr 10, 2012 | Heating & Cooling
Baxi duo tec e160 code
Fault Code E160 on a Duotec Boiler is a fan fault.
Mine has just gone for the 2nd time! Gas engineer is on his way......
Jan 31, 2012 | Heating & Cooling
Instructions on how to re light my pilot light onb a baxi bermuda back boiler picture if possible thanks
http://www.baxi.co.uk/products/bermuda-back-boiler-unit.htm?view=download , i hope that will help
Feb 16, 2011 | Heating & Cooling
How to light pilot light for baxi bermuda sp3
Jul 21, 2010 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Feb 20, 2010 | Heating & Cooling
Baxi bermuda bolier starts up then a big bang
hi no pilot
is too small casing build up of gas hence bang needs service asap
Oct 07, 2009 | Amana AGR5835QD Gas Kitchen Range
Hi there i have old baxi boiler i was wondering
pilot has to be on all the time on this baxi ,piolt might be a bit large might need adjusting down
Oct 05, 2009 | Combi Centre DX - Mango
Heating & Cooling Logo
410 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
