Question about Canon PIXMA MP780 All-In-One InkJet Printer
In copy mode I can't get Image Quality to change from Fine
Pixma mp780 will fast print from pc but when I want to photocopy, I can't change Image Quality from fine (meant for photos). This is very slow and very expensive in ink. Image quality button used to give options of fast, normal or photo. Has a setting been altered? I have tried turning mfc off for an hour to see if settings would resume but it didn't help.
  • 6 more comments
  • Anonymous Jan 06, 2009
    eaxct same problem
  • Anonymous Jan 07, 2009
    I've tried everything and the user's manual is not helpful. It's frustrating because the other options will change but the image quality appears to be locked on fine for copying
  • halimckeon Jan 08, 2009
    I have the same problem. I used to be able to make copies, but now my printer will do a fast print from the computer, but when I try to make copies it is stuck in fine photo mode and it keeps spitting out blank copies. What is causing this??
  • mriley577 Jan 08, 2009
    exact same problem for me too!
  • b_i_k Jan 12, 2009
    My hero! Thanks for that, saved me alot of money as I'd rung both Canon technical advice as well a some accredited repair people to who all said I'd have to bring it in for repairs/replacement buttons possible. Hope this solution worked for the other people with the same problem.
  • Anonymous Mar 15, 2009
    I had this problem and your solution fixed it. Thanks so much! This is generally an okay multifunction printer but getting quirkier all the time so it's great to be able to get help like this.
  • Anonymous Apr 09, 2009
    I have the same problem but cannot see the answer on your website??
  • Mike Gonneville
    Mike Gonneville Nov 19, 2013
    The setting in paper type seems to lock the Image Quality. Set the paper type to plain and then you should be able to change the Image Quality.
Ok what I just found out is that if you use the paper key then the menu key to get down to image quality the n the + and - keys to change the selection.
Posted on Jan 11, 2009
Canon mp780 is stuck on fine mode and it will not
yes, first change the paper setting button to normal, then you can lower the image quality on copies.
Nov 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Need to print darker black copy with canon pixma mp780
Click Start, Click control panel, click printers and faxes, right click your printer, click properties, click printing preferences (near bottom of window), change print quality to high, click apply, click ok, close all windows and try. this will slow the printer slightly.
Jul 05, 2009 | Office Equipment & Supplies
My incoming faxes won't print. both black ink cartridges r full
Is there any message when you try to print the faxes?
If there is an "Image Quality" message, probably the printer is set up to "Copy" in "Photo" or "Fine" mode and it needs to be set to something other than "Fine" or "Photo"
Apr 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do I change image quality
I presume you are trying to copy something on your MP780.
In the "Copy" mode, press the "Image" button beside the LCD screen, then use arrow keys to change to another quality, then press"OK" button and the machine should be set to go.
Jan 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
MP780 copy mode/resolution
Mine was stuck on fine photo resolution too and it wouldn't print in normal black. I tried lots of things and the only thing that seemed to work was pushing the photo button and then pushing the copy button again. Good luck.
Dec 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Print quality stuck on fine
Did you check in the software? There should be a print quality option in your driver software.
Dec 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
MP870 won't copy.
Try cleaning the heads and check print head allignment on the printer, this can usually be done through the printer software or your pc settings
Aug 21, 2017 | Canon PIXMA MP780 All-In-One InkJet...
Print quality
Paper type must be set to "Plain" to select Normal or Fast for Print Quality. Every other paper type selected will automatically set print quality to Fine (Photo).
May 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Can't change image quality
The problem is that only "fine photo pro" is available when the paper selected is photo paper. Change source to the sheet feeder, hit the "Paper" button and then select normal paper. You'll then be able to change the quality to normal.
Sep 22, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp780 Copying mode very slow
is this using it on its own[Stand alone mode] or through the computer?
May 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
468 people viewed this question
old marine
old marine
