Blueparrrot B250 is 1 year old & it went dead so I
  • 416 Answers
How do you know it is fully charged? i think it may be dead battery
Posted on Nov 15, 2012
  • Corey Nov 17, 2012
    Its working the last day I used it. It started it beeping like normal. I put it on the charger & 2hrs later, the function button turned green. As I push & hold the button now, it doesn't power up or respond.
djromann
  • 158 Answers
SOURCE: Acer Aspire One won't turn
You probably get damaged the charging connector, or it is simple dissoldered from the mainboard, thats a very common problem. Check first if it turns on with another fully charged battery. If yes, you should resold the charging connector.
Posted on May 14, 2011
  • 123 Answers
SOURCE: My laptop won't turn on,
Good day. You can try to do these steps which is usually a normal solution to this kind of issue:
1. Take out the battery of your laptop
2. Remove main supply, or power cord
3. Hold power button down for 30 secs,
4. Put only power supply in or power cord
Note: do not put battery in yet
5. Turn laptop on
6. Put the battery in.
If this will not work you might consider contacting toshiba tech support for laptop for other resolution. Hope this information will be helpful in resolving your issue. Thanks for using fixya and have a great day.
Posted on Jun 25, 2011
blsantoso8
  • 115 Answers
SOURCE: we have a compaq presario
You need to replace your old battery. Don't over charged your battery. If you are using your laptop in your house it is better not to use it with battery. Just use the power adaptor/supply only. Then make sure you will drain the battery let say once a week. =)
Posted on Jul 13, 2011
luis_david
  • 407 Answers
SOURCE: ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Posted on Sep 25, 2011
  • 6771 Answers
SOURCE: my battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Posted on Mar 07, 2012
Battery went dead. Tried jump start. Now it will not turn over. Started fine before battery went dead.
Check battery cables, make sure they are clean and tight on the terminals, may need new battery or charge old one 24 hours @ 2 amps.
Jun 25, 2015 | Cars & Trucks
The last 2 days my iphone 4s has gone completely dead within 9 hrs time while not being used & not on the charger. It was 75% when I went to bed and then have nothing upon waking. It's never done this...
Is this since upgrading to IOS7? If not you may have an earthling issue which could be draining the battery. If less than 12 months take back to Apple shop, they will replace IPhone.
Sep 23, 2013 | Apple iPhone 4S
I have a geo metro i believe its a 1996, it says my battery has charge but its not putting a charge through the car. no radio no ac or anything will work. it want even jump. what could this be?
If you open the car door, the production date is on a label
You have the year on your title,your registration & your insurance card
Sounds like a dead battery
You hopefully know how old that is
You could have it tested or if more than
4 years old replace it
Never jump a dead battery ,I know that is what
everyone does & it is a very unsafe practice
Check the cables are in good shape & tight
If they have those clamp on ends buy new
cables that have factory ends
Jul 26, 2013 | 1996 Geo Metro
Battery light flashing
The battery light on, is an indication of alternator failure. If your battery is more than 3 years old it needs replacement . A bad battery can damage a new alternator (full field condition). The age of your truck warrants inspection of the charging system. It requires at Least 20 amps output, from the alternator to run the engine.
May 19, 2017 | 2004 Ford Explorer
I have a 2008 Suzuki Boulevard C90. The battery is about 1 year old, I ride most of the year around and put it on a 1 amp battery charger about every two weeks whether need to or not. Went to start this...
I think you need a battery it is not holding a charge Also take voltmeter when you jump it When running put voltmeter on battery and see how many volts is charging while running It shoud be 13,50 GOOD LUCK MOPAR KENNY
May 22, 2011 | Suzuki Boulevard C90 Motorcycles
Battery in Jeep Grand Cherokee dead this am and less than 1 year old. I have a Everstart 100 battery charger plugged in and on the car. How long does it take to charge the battery. The charger is plugged...
How many amps does this charger put out????
A small trickle charger will take forever to fully recharge a dead battery, you'll need to have a battery charger that can put out enough amps to properly charge a dead battery.To clarify, the chargers sold at Sears, the large square types on wheels are the best for charging dead batteries and they also have an amp meter telling you how much the battery is accepting. After you charge your battery, you should be around 12.5 volts to 12.7 volts. DO NOT OVER CHARGE!!!
Jan 18, 2010 | 2004 Jeep Grand Cherokee
94 nissan sentra brake light/ battery light
Your alternator is dead/dying. Nissan puts both of those lights on to tell you that the alternator isn't charging your battery.
Jun 10, 2009 | 1994 Nissan Sentra 4-Door
Low battery won't charge,change battery,now dead won't charge????
I had the same problem so I got a new battery & separate charger to charge both new & old, then replace as required.
Nov 05, 2017 | Uniden Cordless Phone exai398i
My battery went dead and when I frist plugged into charger it flashed on and then went off and now does nothing wont even charge
sounds like the battery is dead. and will have to get a new one, if it is over 1 year old then it is a possibility.
Jan 22, 2009 | Cell Phones
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
