Does not finish the programm given - Washing Machines
  • map_azzopard
    map_azzopard Nov 07, 2012
    Hoover Nextra 8 HNC 485T
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the make and model number of your unit?
Posted on Nov 07, 2012
What is "delay wash" & how is it operated?
If you're washing machine is equipped with Delay wash.The delay start feature allows you to determine when you want the next wash programme to start. This is particularly advantageous if you want to use night time electricity tariffs or if the programme needs to be finished at a certain time, for instance when you come home from work. You can postpone the start of a programme by up to 24 hours. The display also indicates when the current programme will finish.
Aug 04, 2017 | Washing Machines
Programmer stops at no 2
I would get a quote off the washing machine repair person as the fault could be any where in the system eric
Jan 14, 2018 | Washing Machines
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Calculator missing
Software Flashing or update is the only solution.because calculator is a copyright file.If you can follow the tricks given.Before you do this make back-up all important files like contacts...etc.which is in phone memory
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link rm561_CareDP_13.00_NDT_09.9...exe (66,13 MB) - uploaded.to and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gif Inside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
Jul 14, 2011 | Nokia Classic 2700 Cell Phone
My nokia 7210 shows OPERATION FAILED wen i start MUSIC PLAYER AND RADIO. I am facing dis problem from last 15 days. All the other features are working properly except MUSIC PLAYER and RADIO.
Yes all the other application should work.First follow the steps i have given and if possible SCAN Virus of your mmc .Because the Music player might infected by virus
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link7210c flash file or Nokia flash file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gifInside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
Jul 13, 2011 | Nokia 7210
THE DOOR WON'T COME UNLOCKED
Usually this means that it has not finished its programme cycle. Unplug it from the power source for a few minutes then plug it back in and see if that releases the door switch, if not try to manually turn the programme dial round to its finish position.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Starts ok then skips programmes lights flash then stops without finishin wont complete any programme
starts ok then skips programmes lights flash then stops without finishing wont complete any programme
Jul 02, 2010 | Miele Washing Machines
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Prgramme not starting or finishing
The "mushroom" bottom is just a lever that operate a switch. It seems that a part of the switch's mechanism is broken or release.
Jul 22, 2007 | Bosch 24 in. SGS43C12 Classixx...
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
