Question about Garden
Need manual for 130200 briggs & stratton - Garden
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
  • 17 Answers
SOURCE: craftsman 19.5 lawn tractor w/briggs & stratton keeps flooding
This could be a number or items from no spark to a faulty carburetor, a plugged up air filter, valves out of adjustment, poor gas, faulty spark plug.
First, see if your getting spark, how about taking the wire off a plug(s) and holding it about 1/8" or so away from the plug with some masking tape while you crank the engine. You should be able to see the spark jumping the gap, it helps if it is not too light outside. If you attempt to do this with your hands, you will get a spark jolt, it hurts, so use the tape and remember, the engine could start so proceed with caution.
If you have no spark there, then you ignition or magneto is faulty. This would be unlikely in the broader scope of things. You will likely get spark. Make sure the plug is clean, take it out and inspect. If it is covered in gunk well clean it. It will smell like raw gas but you already know that. Change the plug if in doubt.
Remove and clean and replace the air filter.
If you have spark, and a clean filter it is likely a carburetor problem, Depending on the carb, it could be the choke is faulty or, as per the below.
Depending on what model you have there is a float assembly in the carburetor that stops the fuel from flooding the carb and air intake. The gas tank is higher then the carb right, so if you dont have a mechanism for stopping the fuel from leaking out the hole that goes into the engine, it will all leak out right, as into the fresh air intake because its easier than going into the engine. So, there is a miniature float assembly, sort of like your bathroom toilet float to stop the water. Well there is a small wedge type needle that seats into a hole and it is attached to a float. As the gas rises in the bowl, it pushes up the float, sealing the gas into a chamber, as you use more gas, the float lowers and more gas goes in. So ,there is dirt jammed into the float bowl sealing needle, just a little, thats all it takes. So, shut off the gas somehow, hopefully you have a valve, or squeeze the rubber line, then undo the float chamber, its one nut on the bottom. Clean carefully. The needle, little spring and float assembly are delicate. Also, the needle could be worn from engine vibration, so it may need a new needle. It would help if you described the engine and carb though.
I posted that as a solution to another problem, but yours may also be the valves need adjusting. Depending on the amount of hours, say over 200, then the valves timing will likely be off a bit. Check the clearances with a feeler gauge, it is not as difficult as it seems. Check your Owners manual for the clearance at top dead center. TDC is when you take the plug out and watch the piston arrive at the top of the cylinder through the spark plug hole when you are turning the engine over (do this by hand, battery off. Make the adjustments with the valve cover off. Follow the instructions.
Hope some of this helps.
Posted on Sep 21, 2009
  • 110 Answers
SOURCE: want a repair manual for a 17 hp briggs &
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
Posted on Oct 03, 2009
  • 18 Answers
SOURCE: wanted briggs and stratton 92908 manual
Find the B&S website and you should be able to download a parts or service manual.
Think it is briggsandstratton.com.
You will also need your type number (after the 92908).
Posted on Apr 18, 2010
mikehowy
  • 177 Answers
SOURCE: I would like a user manual for a Champion R484TR lawn mower.
google
Posted on Jun 07, 2010
13 HP briggs and stratton intek motor on a pull behind weekend warrior brush cutter
Manuals - Briggs & Stratton
https://www.briggsandstratton.com/us/en/.../manuals
Briggs & StrattonFind Briggs & Stratton manuals online by selecting your lawn mower or product type &engine model number. Never worry about losing an owners manual ...
Sep 10, 2015 | Measuring Tools & Sensors
HOW DO I GET A REPAIR MANUEL FOR A BRIGGS AND STRATTON 12 HP IC QUIET ENGINE
Try website for Briggs & Stratton. Or use Google Search for Briggs & Stratton 12 HP IC Quiet Engine Manual.
Oct 02, 2014 | Heating & Cooling
I have a Briggs & stratton 18hp ohv riding lawn mover. Model # 31D777 type: 0233 E1. Do you know where I can find an Owner's manual that can be downloaded on the computer? Went to briggs & Stratton...
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. harmsen2@bigpond.com
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Hi Need repair manual for Briggs &Stratton
go to your nearest tool rentall place they might have a book or beable to guide u inn the direction of finding one
Jan 24, 2010 | Garden
Want a repair manual for a 17 hp briggs & stratton engine
Oct 01, 2009 | Garden
Briggs & stratton 28u707 1112-e1 repair manual
go to partstree.com
find briggs &stratton
or to the left of the screen enter your number you gave
Jun 20, 2009 | Briggs & Stratton Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
