Question about Watches
Which coat is better?
Http://jackets.cwmalls.com/womens-leather-coat-cw695161.html http://jackets.cwmalls.com/mink-fur-collar-leather-coat-cw691259.html
2 Suggested Answers
  • 906 Answers
SOURCE: [url=
good day,
hope this link below will solve your problem.
watches
Posted on Jul 30, 2010
Tip
ANTIQUE CLOCK CLEANING TIPS * The question of how to clean your clock is quite a...
* The question of how to clean your clock is quite a controversial one, as many Master Clock Smith experts have used many different techniques, which can also may be unique to your geographical location.
* Many cleaning solutions and chemicals are suitable. However, We use a water-based formula.
* In deciding the proper solution to use, you will want to observe all hazardous material and EPA regulations in your area. For example, after the cleaning solution or chemical is polluted beyond use how do you get rid of it?
* In years past, it appears that the water-mix formula was the most popular choice. In more recent years, highly active commercial products seem to have taken preference. Currently, we have disposal problems, as many cleaners have been defined as toxic waste. I believe that as the Clock repair business evolves, we should seek and use a less hazardous cleaning solution.
OBSERVE CAUTION
* Always protect eyes and nose when handling cleaning solutions.
* Do not allow movements to remain in the cleaning solution for extended periods of time.
* Use gloves when handling cleaning solutions.
· Special care must be taken with "Bright" movements since these are protected with a "vellum" or thin coat of lacquer. The cleaning solution can loosen and peel this protective coating if the movement is immersed very long. If the lacquer is loosened when cleaning, small bits and pieces of the vellum can clog wheel teeth, pivots and pinions and will require a great deal of unnecessary hand cleaning and effort to remove.image006.jpg
CLEANING THE "AVERAGE" CLOCK
1. Pay very close attention to the type of "clear coat" used on the clock, many clocks use a clear coat that is applied to keep the brass shiny and acid free. If your cleaning solution is too strong, it will remove it unnecessarily. If this happens, it is best to completely remove it and in the end re-apply the clear coat.
2. REMOVE all plastic gear levers and sensitive parts such as a floating balance, as it will tend to trap the solution in the tube. "It will however require a different procedure."
3. I use a 3-step cleaning method:
Step 1. Dip the clock in the cleaning solution mixture. Then brush all large deposits of grease and dirt from the clock, drench the clock in warm water and shake dry.
Step 2. You must [COMPLETELY DISASSEMBLE THE CLOCK as it can not be cleaned properly otherwise] and let soak in a weaker cleaning solution (20 minutes or so will work fine). With a tooth or gun cleaning brush thoroughly clean all wheels, pinions and pivots and un-coil the spring with a Main spring UN-winder.
Step 3. Let it soak in warm water only for 20 minutes, this will neutralize and/or dilute the cleaning solution that is still present in the pores of the metal.
4. Drying: It is very important to thoroughly dry the clock, the theory being that metal is somewhat porous in nature and will tend to hold moisture like a sponge.
DRYING THE CLOCK MOVEMENT
Step 1. Dry with a hair dryer until totally dry.
Step 2. Put in a pre-heated oven at about 180 degrees for about 20 to 30 minutes, this will dry out all moisture from the clock. NOTE: Don't get it too hot, just to the point that you can't handle it is fine.
Hope this tip Helps
R/
David
http://antiqueclock.clockstop.com/CLEAN.htm
on Jan 22, 2010 | Watches
My Michael kors mk8108 watch strap, the white coating on the metal link has started 2 peel & fall off can u get replacement links need a few
Perhaps you better contact the shop, where you bought the watch. We try to help people with answering questions. Not selling or providing articles.
Jun 04, 2014 | Watches
Replacement buttons
Where do I find Kenneth Cole Reaction replacement buttons for a man's coat
Feb 19, 2014 | Kenneth Cole Watches
THE MARKERS AND POINTERS OF MY ROLEX SUBMARINER ARE NO LONGER LUMINOUS IN THE DARK. CAN THEY BE RE-COATED? ANY IDEA OF COSTS INVOLVED
They can be re coated or replaced.The watch will need to be re sealed after so now may be a good time to service the watch as this is advised every 4/5 years.
A service will cost £275.00/£325.00 and takes 2/3 weeks at www.rolexrepairs.co.uk
Regards
Aug 09, 2010 | Rolex Submariner 16618 Wristwatch
I can not set my watch to have the hands glow during the nighttime....it does during the day time, I have tried changing the time by 12 hrs and it does not fix the problem
if your hands have a luminescent coating they get 'charged' by light but only for a short period of time...try sitting it under a light for a few minutes, they should glow after that
Nov 09, 2009 | Bulova Watch
Watcmaker has advised the circuit in a piaget ladies smallquatz watch requires replacement can you advise please
once the circuit is cut the watch stops and leaves ur 2 options. o
1 replace
2 the make a circuit glue which coats the whole circuit and most cases restores power, this is very inexpensive. they dont recommend cause they want to sell parts
Oct 09, 2009 | Piaget Watches
Blurry Lenses
buy some new lenses, that are not nike...ray
May 29, 2007 | Nike Triax 50 WR0083-029
Watches Logo
46 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
