Question about Samsung Washing Machines
Flashing SE and stop running, there is still water inside
Model WF8802RSW 8.0 kg
    Top Expert:
  • Samsung Master
  • 9,472 Answers
5E error
WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drainerror can be cleared by turning POWER SW OFF and back ON.
Posted on Nov 07, 2012
Hello i have LG washer 7 kg when the motor work a few minute the display show SE if i press switch start his continue normal and repeat this state after any time
@Mowafak
"LG 7Kg SE error...."
Hello M,
The error is 5E not SE.
They look the same on a digital display :)
This is a "Water not draining out" problem.
The machine detects level of water while draining.
If this does not drain in a 15 minute time-out, error 5 "5E" pops up on the digital time display.
Somewhere in the draining path, there is blockage.
Try this:
Check your drain hose for blockages, and that it is installed the correct way.
Remove the drain hose - prepare for a possible flood from the machine drain if you do this!
Use a garden hosepipe or strong pressure tap to flush hose forward and reverse until water runs clear.
If you live in a very cold climate maybe the hose is iced up inside.
Also check all filters to see they are not blocked up.
Hope this helps,
Clive.
Oct 18, 2017 | LG Washing Machines
Hoover clothes dryer 3.5 kg 3525D stop working
If it does not even start then it is power supply.
If it stopped running at all then it is probably the motor.
If it runs but not dries is the heating element to be replaced.
Post make and model to get parts and diagrams
Apr 23, 2008 | Dryers
Hi I have a midea mqb80-700b 8 kg washing machine and sometimes it doesn't stop filling to the point of over flowing
Hi, you have to get your machine checked for the water sensor or water inlet valve as one is not working properly.
Dec 27, 2015 | Washing Machines
Fuzzy logic 12 kg model T9507TEFT0 overfills water
your water level switch is most likely bad or there is trash in the line feeding it.
Mar 17, 2014 | LG Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
Jul 06, 2010 | Washing Machines
What is the conversion of Kg water to Kg petrol
One KG of water is one liter, one KG Petrol is approx 1.356 liters.
Or one liter of water weighs One KG and 1 liter of Petrol weighs 0.737 KG at 60F
Jan 12, 2010 | 2009 Toyota Avalon
Water leaks from my Aquasmart 8 kg washing
On most units, the water pump was a "weep" hole on it which tells you pump needs to be changed soon. It tells you the internal seals are starting to fail.
Dec 28, 2009 | Washing Machines
Keeps flashing SE
I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
Mar 30, 2009 | Samsung Washing Machines
Washing Machines Logo
501 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
