Question about GE Prn 50-m Printer
Cannot change paper on the GE PRN 50
I have tried changing the paper but it tells me the door is open and will not print
Change paper cartridges.
Posted on Nov 06, 2012
I printed an envelope using word and now my printer won't print regular papers from my web sites.
Try opening the door in the back of the printer and return the lever that switches between envelopes and paper back to the original position.
Oct 19, 2014 | Brother MFC Office Equipment & Supplies
My MF5770 display alternates between "Change papersize" and "Check papersize" and will not print. Turning off does not solve the issue, nor does going thru' the menu to change...
You have to check both trays, the cassette and the manual feed:
The Cassette:
Remove the paper tray and inspect everything.. remove the paper, move all of the paper guides and make sure they all lock into place where they should (LTR, LGL, etc)
if the paper size guides are broken/damaged then the machine may not be able to correctly tell the size.
The Manual Feed:
Open up the front door, remove the toner and check the area around the manual feed. You're looking for the flag that tells the machine there's paper in the MFT. If this is stuck it's possible it's incorrectly trying to pull from there.
Jun 01, 2011 | Office Equipment & Supplies
My Brother MFC-3240C printer does not print crisp images. Colors are washed out and lines run though the images. I reinstalled the CD and no luck. Can you tell me what to fix?
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 25, 2009 | Brother MFC-3240C All-In-One InkJet...
Try to print directly to DVD with a canon pixma
>> It tells me to close the door so it can resume printing on paper normally A4.
It is trying to "ignore" the "bypass" try.
Tell the printer to *ACCEPT* the disk from the "bypass" tray,
rather than from the stack of paper in the A4 tray.
To tell the printer, click the OK button on the printer.
Nov 08, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
HP printer will not feed paper.
Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
    NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again. If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened. Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product call in to hp at 1800-474-6836 and ask for an upgrade on which you shall get atleast a minimum of a 50% discount on the printer cost.
Jun 25, 2009 | HP DeskJet 1220c InkJet Printer
Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
May 07, 2009 | Adobe Acrobat 7.0 Professional
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
My Oki B4545 MFP alarm always on
Solution provided by printer manufacturer tech support which worked for me.
1. Open all doors (front & back)
2. Remove tonner
3. Turn off power
4. After 20 secs turn on power
5. Close back door
6. Insert toner
7. Close front door
Fixed now!
Jan 25, 2009 | Oki Electric Industry Oki - B4545 MFP...
GE Prn 50-m Printer Logo
205 people viewed this question
Top GE Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a GE Health and Beauty Expert? Answer questions, earn points and help others
