Agitator slow and leading from bottom - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the make and model number of the unit?
Posted on Nov 06, 2012
Agitator running slow and leading from bottom
Nov 07, 2012 | Washing Machines
Kenmore Series 80 washer. Agitates too slow
check the dogs in the agitator take off the cap it should rachett if it turns free replace the dogs in the agitator
Jul 12, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator very slow
I changed the motor coupler, but now it fills and spins ok. but agitate very, very, slow
May 16, 2010 | Washing Machines
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
The slow weak function of the augar
the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 15, 2009 | Whirlpool LSR6332K Top Load Washer
Kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Model #82881110
Remove the dispenser cap by pulling it straight up. Under the dispenser cap, there may be another cap. If so, remove the center cap exposing the agitator bolt. Using a socket and ratchet remove the agitator bolt and the top half of the agitator can be lifted out as one piece. With the top portion of the agitator removed, grasp the lower agitator by the bottom flanges and pull straight up. The remaining section should lift off the center post. For a helpful illustration of what I'm talking about, go to searspartsdirect.com and type in your model number as "110.82881110". Go to the "Agitator, Basket and Tub" heading. There's an exploded view illustration of the agitator and all the components. If you require parts, all the part number and pricing information is available, as well. I hope this helps you.
PS When re-installing the agitator DO NOT over tighten the agitator bolt. This can cause damage to the agitator and create slow rotation problems. Just make sure you tighten the bolt snug, and then give it about a 1/4 turn.
Oct 09, 2008 | Washing Machines
Remove Agitator Whirlpool style Top Loader
i think that the agatator may have a screw in the side of it nearer the bottom stem if so slacken off and pull ajatator off main shaft
if no screw just pull agatator off
sometimes takes a bit to get off
do not turn machine upside down
Feb 01, 2008 | Washing Machines
Top load Whirlpool washing machine
Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
Nov 02, 2007 | Washing Machines
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
