Question about Nextar Q3 GPS Receiver
Problem with nextarx3-08 gps
My nextar x3-08 wont read the sd card. it says to properly insert it but it is
  • 4 Answers
You will need to re-format your card from your computer then re-download gps program to the card
Posted on Jan 05, 2009
How do I update my Nextar x3-08 gps so the new roads will show up ?
visit Nextar.com to order your desired maps update and Check the overview description to see which SD card lists your GPS model number and serial number. Order the matching card.
Remove the existing SD card. This is usually found in a thin, rectangular slot on the side of the Nextar GPS.
Insert the SD card with the maps update into the empty SD card slot. Press until it clicks into place.
Reset the unit by pressing the "Reset" or pushing a pin into the "Reset" hole.
Click the "Navigation" button to have the maps automatically update on the GPS.
May 06, 2015 | Nextar X3-08 Car GPS Receiver
I have a nextar x3 gps and for some reason it will not turn on it just froze what can I do.
First, take out any SD cards you may have in it. Pull the stylus out of the back, and use it to press the small RESET button between the SD slot and the stylus... hold it in about three seconds.
This will reset the unit.
Mar 30, 2011 | Nextar X3 GPS Receiver
I have a Nextar x3-08 gps. It will not go beyond the opening screen. It just suddenly stopped working. Any idea what may be wrong with it? Thank you.
Once again, it's a software issue or a corrupted SD card. You can purchase a new card but the same old mapping on Nextar.com or Navteq.com. To ensure that your software stays working properly, backup the SD card onto your computer so if the SD card gets corrupted you can restore the software and files back onto your card or a new SD card that can be purchased for around 20 bucks.
May 26, 2010 | Nextar X3-08 Car GPS Receiver
Constant rolling screen.will not navigate.
You are having a software problem. Your SD card somehow became corrupted. Best solution is to get a new card from nextar or navteq. Both carry the SD Cards with the mapping software on it.
May 20, 2010 | Nextar X3-08 Car GPS Receiver
Doesnt go to navigation screen nextar x3-03
If it says it can't find map data then your SD card is corrupted.
It's a fatal flaw in the WindowCE 5.0 operating system that was used for Nextar GPS builds. Basically, if you have a power glitch while it's reading your SD card (contains the maps) then your SD card get's corrupted.
Don't expect any help from Nextar. You will have to get the original data from another person's SD card with the exact same model
Sep 13, 2009 | Nextar X3 GPS Receiver
My nexter x3-03 wont go pass the navigation screen it only shows 3 green bars
make sure the sd card has not been altered or formatted as all the information and map is on the provided SD card.
Aug 14, 2009 | Nextar X3-03 Car GPS Receiver
Unit indicates mapcard not inserted properly but it is
card is possibly blank send it back. buy a marbella altina Nextar are unreliable GPS If in Australia see www,nettiser.com.au/marbella/
e3ven outside australia the maps are available for all countries and the unit is reliable and easy to service, also has a mkap backup service if registered.
Jun 20, 2009 | Nextar X3-03 Car GPS Receiver
I called Nextar and you have to let its battery drain completely and then plug it in to charge for 5 hours. I guess it a glitch in the system :(
Jan 05, 2009 | Nextar I4-BC GPS Receiver
Hgow do i down load music
You load music onto the SD card then it will play from there.
Apr 19, 2008 | Nextar X3-02 GPS Receiver
Nextar Q3 GPS Receiver Logo
143 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
