How do i view configuration information on Epson LQ-690 Printer? E.g. Baud rate, parity, stop bit, etc
IB4G2008
  • 3587 Answers
SOURCE: How do I change baud rate to 9600 on Epson CX9400Fax?
here's a good place to start..see the user manual at the bottom of this page
Posted on Jun 01, 2008
alvinbga
  • 130 Answers
SOURCE: Printer Epson LQ 2090 out order
Light Pattern Beep Pattern Problem
Solution
________________________________________________________
* Paper Out light An unknown or serious
* Pause serious error has occurred
** Tear Off/Bin ..... ______________________
*** Font Light Turn off printer and leave it
*** Pitch Light off for several
seconds; then turn
on the printer again
Posted on Jun 19, 2008
SOURCE: Epson LQ-1050 Matrix Printer Problem
I am getting my text cut off at the bottom what could be the problem
Posted on Apr 01, 2008
wayneard
  • 1901 Answers
SOURCE: oki 320 turbo, serial interface, how do I change
To change the settings, make sure you have a good ribbon installed.
Press the MODE button. The SEL light will go out. Menu light will come on.
Press the GROUP button until the printer prints something like:
Serial Interface Parity None
To change the Parity, press SET. A new line will print as:
Serial Interface Parity Odd
Press SET until the Item is the one you want.
Then Press the ITEM button. It will then print:
Serial Interface Serial Data 7 or 8 bits 8
Again if you want to change it, press SET. Otherwise go to the next Item.
Continue using the ITEM button to choose the item you want to review or change and the SET button to change the selection.
When you have made all the changes verify by going through all of the items with the ITEM button. When you are satisfied, Press the MODE button to save all of the changes. (The Menu light will go out.)
If you have any trouble Comment back.
Thanks for using Fixya.
Posted on Aug 27, 2009
SOURCE: HOW TO SET BAUD RATE
HOW TO SET BAUD RATE 9600 OF EPSON LX 300...
Posted on Dec 05, 2010
I'm trying to figure out how to connect my Datamax Prodigy Plus Thermal printer to my PC. I have a 25 pin connector on the Printer labeled J2. Also a round plug-in labeled J4. My computer has the same...
If the cable works on the Zebra it should work on the Datamax. It must be a RS232 serial null modem cable.Check the serial port settings and make sure the printer setting match the PC serial port settings. Baud Rate=________? Data Bits=________? Parity=_______?Stop Bits=________? Handshaking=____________?
The typical settings are Baud 9600,8,n,1 Xon/Xoff.
Also make sure of the comm port being used. com1,com2......etc
Jun 09, 2011 | Datamax Prodigy Plus Thermal Printer
I need drivers epson lq 690 xp
Hello
Here is the link to download drivers fro LQ690 for XP
http://www.epson.co.uk/Printers-and-All-In-Ones/Dot-Matrix/Epson-LQ-690/Drivers-Support?supportLandingPage=true#
Hope this helps, do rate the solution if helps
Jan 08, 2011 | Office Equipment & Supplies
Printronix P5005B printer printing garbage after configuration
If using RS 232 serial communications, verify that host and printer settings match. Baud Rate, Parity,Stop Bits, 7or 8 bit word length. Example 9600,8,n,1
Or make sure it is not in hex dump mode.
Sep 24, 2010 | Printronix Line Matrix P5005B Printer
I have an Epson TM88II and it only prints question marks. How can I solve this
??? Assuming using serial port ???
Question marks are substituted for bad data.
Normal reason for this is incorrect Baud rate.
Test:
Power on printer while holding feed button.
Current settings including baud rate will be printed.
Press feed a second time to complete the test print.
Set port to setting specified by printout.
e.g.
(at command line)
mode com1:9600,N,8,1
mode port : baud , parity , data bits , stop bits
I hope this helps
Mar 12, 2010 | Epson Office Equipment & Supplies
Need to connect to the console port what are the settings
This all depends on what model of firewall you have.
But the settings are most likly
Baud Rate: 9600
Data: 8 bit
Parity: none
Stop: 1 bit
Flow control: none
You may need to play with the Baud Rate
Oct 20, 2009 | Computers & Internet
Need configuration and reset barcodes for Symbol LT1820-I100A
Hi, the LT1820 is strictly an RS-232 device. The Product Reference Guide can be found at the link below and the Set Defaults barcode is on Adobe page 47 of 105.
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=0804302bpdf&sliceId=&dialogID=14395378&stateId=0%200%2014391883
This scanner's default RS-232 settings are 9600 baud, Even parity, Two stop bits, 7 data bits, and no hardware or software handshaking. Standard RS-232 is normally 9600, 1 stop bit, 8 data bits, no parity, no hardware or software handshaking. I hope this information helps.
Oct 10, 2009 | Motorola Computers & Internet
Running two Zebra's through Easylabel Platinum
When connecting Easylabel to a Zebra through the RS232 port, it's very important that the serial settings match between Easylabel and the printer. Easylabel defaults to 9600 baud, 8 data bits, none parity. The Zebra defaults to 9600 baud, 7 data bits, and even parity. This mismatch causes the data light to flash but no print.
Change the printer setting to 8 data bits and none for parity and the baud rate can be whatever but make sure they match from Easylabel to the printer.
Hope that helps !
Sep 18, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Printing labels
Bubbabear64: Oops. Sorry if I interefered by requesting info after yours.
Sarahq993:
I could be wrong, but I think you are connected through a (null modem) serial cable without proper flow control, so the printer fills up with an error condition after 60 labels. If you're usinf this caqble, it would be screwed into a nine pin connector on your PC and would be screwed into a 25 pin connector on the lower part of the back of the printer. If I'm wrong, please let me know and I'll try again.
There are two banks of dip switches on the back of the printer, with a chart showing their meaning (baud, data bits, stop bits, parity). The switches are only read when the printer powers up, so cycle the power if you change them.
The settings on the PC must match these settings.
Right click on the printer name, select "Properties", "Ports", (probably) "Com1", "Configure Port". Set the same baud, data bits, stop bits and parity as the printer, and also turn on Xon/Xoff flow control.
Please let me know if this works, or if I'm wrong.
Label_Guy
Sep 23, 2008 | Intermec EasyCoder 4400 Thermal Printer
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
Prints gibberish
print a selftest:
turn printer off then hold down the feed button, turn printer on and release feed button whenever it prints something.
pls reply back with info on printout, such as baud rate, parity and other info specially interface, thanks
May 13, 2008 | Epson TM-T88III Thermal Printer
79 people viewed this question
jasbo
jasbo
