Need a thorough explaniation on how to fix this problem on my IBM Thinkpad R50p laptop it just says pxe-e61 media test failure check cable pxe-mof exiting intel boot agent operating systerm not found
    Sergeant:
  • 416 Answers
BIOS - boot priority - here removeall devices and live for boot only system HDD then try it, if same problem, then remove HDD and look to jumpers settings on HDD, if it is set to Master, then set it to Slave and try againe
Posted on Nov 15, 2012
  • 298 Answers
SOURCE: My Toshiba satlelite A105 will not boot up ,
Go into SETUP (F2, DEL, Cntl-S or somesuch at boot time - or hold F1 key down and force and error and then change your BOOT order to CDROM, HDD. It is Currently NETWORK, CDROM, HDD or the like.
PXE is Network directed bootup, and your LAN connection is waiting or the proper code or instruction or server. You need to turn that off, and BIOS SETUP is where to do it ;-)
Hope that helps
Posted on Apr 08, 2009
  • 37 Answers
SOURCE: PXE-E61,PXE-MOF,OPERATION SYS MISSING
I have three kids with the same Acer Aspire 3680-2681. All in over a year have had this. The first sat til we gave up and just tore apart. Put back together, it worked, better. Nothing done. The second, a couple months later, we just took out the hard drive, made sure it was in the correct and full way in, and it worked. This week, the third, same problem, same solution, Took out the hard drive, put it back in snuggly and it worked. It has two screws that SEEM to hold it in place but it does slip out. BEFORE you do all these other ms-dos things and other crazy time consuming file losing pictures forever gone things, try this, and bring a can of compressed air, get the dog hair and dust out while you are there.
It seems to be a small engineering thing with the screw placement and holding of the thing securely in my humble opinion.
Posted on Sep 15, 2009
moshek
  • 65 Answers
SOURCE: PXE-E61:Media test failure, check cable PXE-MOF:
If you get that error, it means that the laptop was trying to load Windows over a network - which is only used in Corporate setups.
Try going into setup (usually pressing Del, or one of the "F" keys as soon as it turns on), and checking if it's detecting your hard drive.
If it is detecting your hard drive, check the boot order - it's possible that the computer is set to try to turn on from a network before it tries to turn on from the hard drive inside - if that's the case, change the order.
Posted on Dec 22, 2010
  • 80 Answers
SOURCE: Hi Im having a problem booting,
From that error message, it looks like you either have the wrong hard drive connected to the main hard drive SATA slot (if you're using SATA cables) or your operating system was corrupted. Unfortunately, if your operating system is corrupted, you will need an external device or operating system CD. If this is a laptop, the news is leaning towards needing a reformat, especially if the laptop already came with an operating system installed.
Posted on May 04, 2011
  • 18 Answers
SOURCE: Booting problem, screen message: Intel (R)
looks like it's unable to find the harddrive to boot from. It's trying to boot from a network location now.
Try entering the bios and see if you have an option to run a scan on the harddrive
Also check the boot options - make sure that it starts from the harddrive BEFORE it tries to boot from network.
How do i install a operating system on my ibm thinkpad 122m i have tried everything ?
not many options pick one...CD ROMLANUSBwhat os are you trying to boot into, the machine may not support it, let me know so we can get this done!! good luck question just ask
Mar 30, 2013 | IBM ThinkPad A22m 2628 Notebook
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
Keeps saying boot failure along with Ethernet controller v1.06 and media failure, check cable
What you are describing is a hard drive issue, remove hardware and reseat it back in place sometimes this will restart the hard drive. If this fails have it tested.
Jun 04, 2012 | MSI Computers & Internet
My IBM T20 Notebook is given me this message -PXE-E61: Media test failure, check cable- and then say -Operating System Not Found- ---- What do I do?
The error message PXE-E61 is Network card that try to conect this is because hard drive failure or Operating System
check on the bios if you can see the hard drive if you see the drive it could be the OS
hope it will help
Nov 02, 2010 | IBM ThinkPad T20 2647 Notebook
I keep getting codes pxe-e61 media test failure,
Something went wrong with your last installation. try reinstalling windows. But, before that go to BIOS and check the BOOTING devices
Nov 18, 2009 | IBM ThinkPad T42 Notebook
From the first time I try to start my new lenovo 3000 g530 4446 3fg it tells me pxe-e61 media test failure check cable, pxe-mof: exiting broadcom pxe rom and I made the laptop boot from the hdd but it gave...
The PXE-E61 error is caused by either a faulty disk controller or most likely a faulty hard disk. Because the Lenovo is new I suggest you return it to the supplier to get it fixed under warranty.
Do not try to fix it yourself because you can void your warranty.
Sep 27, 2009 | IBM Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
