Question about HP Laserjet CM2320nf All-In-One Color Printer
Laserjet cm2320 mfp with purple screen
I have a laserjet cm2320 mfp that is giving me a purple scree.when i switch it on the hp logo apperas boots halfway then a purple screen appears.i tried to change the formater board but still i get the same error.
  • LAura Aug 28, 2013
    Hi, Ihave the same problem. then appears the purple screen are two leds (ready and attention) that turned on and I can't use the printer. How have you solve the problem?
haivanko
  • 37 Answers
SOURCE: error 6 hp laserjet 1120 mfp
The problem is that the motor that drives the scanner probably overheated and because of the cheap plastic that HP used it melted important points that the motor relis on...so - remove the glas of the scanner(there are some screws - one of them hidden under the label of the panel,unhook the interface cable of the panel).Now you should see the scanner - flip it over and look at the motor exle and the gear that it should mesh with - they are not aligned at this time.To fix it i used 2 small pieces of plastic - sticked it under the motor so that it can not move in vertical direction anymore. Simply this is the solution that i used and it works just fine :) If you have any questions dont hesitate to contact me. alpescomputers@winetbg.com
Posted on Jun 15, 2009
  • 102 Answers
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
SOURCE: scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Posted on Jan 14, 2010
  • 1382 Answers
SOURCE: How can resolved Scanner error 12 in Hp Laserjet
Try to uninstall the software of your scanner and reinstall it again. Also
check your cables for loose contacts.
Thank you!
Posted on May 18, 2010
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
Posted on Jul 26, 2010
I have HP LaserJet Enterprise 700 color MFP M775dn ptinter and i forgot the username and password to access the setting through the web, any way to reset it please ?
You will need to perform a partial clean. Turn off the printer. Turn it on and watch to boot up on screen closely. When the black line appears under the HP logo, touch the HP logo. Display will go to a black and blue display. Use the arrows on screen to scroll down to administration, select partial clean and press ok, and then press back arrow until continue appears on screen. Press ok and unit will restart. You will lose most of your settings this way but you have no other choice.
Oct 21, 2016 | HP LaserJet M775DN Laser Multifunction...
Adf door open error can't resolve
Hi there, my name is Lisa and I'd be happy to help you with your LaserJet 3055.
I see you are getting an ADF door open error and can not get passed it. Please use the following 2 documents to troubleshoot the issue:
http://h20566.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=1161389&docId=emr_na-c02713189&docLocale=en_US
HP Color LaserJet 2820 40AiO CM1312 MFP CM2320 MFP LaserJet M1522 MFP...
I hope this helps, but if the issue persists you might consider calling us. What you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
Best of luck.
I work on behalf of HP.
Jul 02, 2015 | HP LaserJet 3055 All-In-One Printer
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
My HP 4345 mfp will not boot up, the HP logo keeps flashing on the screen
When the memory counts up when turning mfp on, hold down the 6 button until all three lights on left of panel light up, then using the 3 button to scroll go to COLD RESET and touch 6 button to select. If that doesnt fix ya then you may need a hard disk drive
Jan 25, 2010 | HP LaserJet 4345mfp Printer
HP Color LaserJet CM2320 MFP shutting off and on -does not work
unplug the telephone and network cable and restart the printer.
Dec 11, 2009 | HP Laserjet CM2320nf All-In-One Color...
Laserjet cm2320 fxi mfp has scanner error 5
when Printing from my HP 2320 there is a slight blue streak on the Right side of the page
Jun 03, 2009 | HP LaserJet 2840 All-In-One Printer
HP Laserjet CM2320nf All-In-One Color Printer Logo
205 people viewed this question
Seeker5211
Seeker5211
