Question about One For All URC4110 Remote Control
RM36E+ CODE Hai, would you mind give me a code for my remote type Rm36e+ and my tv TCL? thankyou so much if anyone give me a solution soon.
5 Suggested Answers
pinay311
  • 3 Answers
SOURCE: CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
Posted on Jan 30, 2008
  • 54 Answers
SOURCE: Help for Sansui URC-3605 one for all remote control codes. Need T.V code.
You will find all codes and needed information here...
http://www.hifi-remote.com/manuals/
Just look up your model number and wallah!
Posted on Aug 17, 2008
SOURCE: I have a tevion remote. I need the code for TCL TV
lost my instructions can't program it
Posted on Jun 01, 2009
shawty-lozzy
  • 151 Answers
SOURCE: remote control code Akari IC1494P2?
what make is the remote? codes are different on other remotes
Posted on Jul 20, 2009
koolmind
  • 75 Answers
SOURCE: I have just purchased a Control Freak Universal
try these codes:
0054-0690-0037-0056-0012-0323-0554-0191-004
Plz dont forget to rate
Posted on Sep 07, 2009
How I program RM36E++ for tv SONY FILLIPS??
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Oct 28, 2016 | Philips Televison & Video
How I can program universal control RM36E for tv SONY?
One way is to use code search to find something that can handle some or all functions of your Sony TV.
Oct 28, 2016 | Universal Televison & Video
What are the remote codes for a Summit Broadband DTA digital adapter remote to operate a TCL 26" HDTV?
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
Jun 01, 2015 | HCDZ General Remote Replacement Control...
I got the huayu rm36e+s universal remote. Unfortunately there is no code listed for JAI TV. What is the code ???
  1. Turn on the TV first.
  2. On the remote, press SET for 3 seconds, or press SET and POWER, until indicator lights up. Release the key/s at the same time.
  3. Press and release the POWER key. The indicator will flash every few seconds. What it does is cycle through TV codes and transmit a "Volume +" command on your TV.
  4. Pay attention to the TV. When you see the Volume being adjusted on the screen, quickly press SET. The indicator light will turn off and you just successfully programmed your URC to work with your TV.
Apr 06, 2015 | Universal Televison & Video
Tcl tv code for directv remote
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
DirectTV remote control code list is given.
Oct 14, 2014 | TCL L32D20
Unlocking code chunglap universal remote control for tcl tv
TCL: 051, 053, 068 Unlocking code chunglap universal remote control for tcl tv
Jun 29, 2012 | Televison & Video
On my dometic refrigerator, modle# rm36e, prod # 9264530, ser # 7090209 the piolt lite will not stay on when I let go of the button
Just like with any older pilot light gas appliance, your refrigerator has a thermocouple which senses heat from the pilot and sends an electrical signal to the pilot valve when it is properly lit. I suspect this thermocouple has gone bad. It will look like a probe sticking into the area of the flame from the pilot and will unscrew from some sort of mounting bracket and have a wire on the other end that plugs into a connector. Generic versions may be available at home appliance repair centers but original replacement would be the best choice. RV repair centers and supply stores will carry it. Do an online search for RV repair supplies or more specific search for Dometic repair centers.
Apr 04, 2012 | Refrigerators
My tv is a tcl brand model tcl-14175 i accidentally on the child locked.can I have the child lock code for my tv?please
my tv is tcl model ( t1436a ) , lost my tv's remote controller , please give the model number of remote controller
Sep 24, 2009 | Tvone TV-207 Television
Chunghop RM-133E universal remote
Go to www.chunghop.com/en/ for the answers.
Mar 11, 2008 | Televison & Video
Codes for TCL TV on the Chunghop universal remote
most universal remote would work like this... press butons tv and power on at same time till red light of remote lights still. then press 110. then presto, it works... i hope i help in a way.
Jan 30, 2008 | Universal Remote Control Remote Control
One For All URC4110 Remote Control Logo
1,373 people viewed this question
Top One For All Televison & Video Experts
Electro Med Services...
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
