Question about Janome Memory Craft 10000
My Janome 10000 seems to have jammed the fly wheel won;t turn, There is nothing stuck in machine, needle is not bent
Is it possible that the computer board is going. It sometimes clears itself if you turn it off and leave for several hours.
  • Janome Master
  • 7,365 Answers
Yes, it is possible. or a part inside the machine could be broken
it would be a good idea to have the machine checked.
Posted on Nov 06, 2012
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
Alleluia
  • 69 Answers
SOURCE: Dear Sir,
There is a chat room for Janome sewing machines at following link:
http://sewing.patternreview.com/SewingMachine/Janome/
Hope this helps
Alleluia
Posted on Nov 14, 2008
  • 8 Answers
SOURCE: Janome Customizer 10000
There are different programs for 350E. I think, you was buy program different.
Posted on Jan 11, 2009
Mongo32
  • 111 Answers
SOURCE: When sewing the bobin thread tangles and jams
upper tension/threading wrong?
Posted on Jul 08, 2009
drifterK
  • 4924 Answers
SOURCE: My Janome 10000 is coming
the error is cause by the sensor that detected it in the first place ..what you should do is reset it to the factory setting s...Look in the main menu for reset to factory settings or defaults..and engage them ..
Posted on Aug 22, 2010
My janome me 10000 keeps giving me a warning message that says is fabric to thick is needle bent is something stuck in machine. I just had a new circuit board put in. Why is this doing this
That is the wierdest error message I've ever seen on a sewing machine. Did you try a brand new needle? Are you sewing thick fabric (does the message appear when sewing light-weight fabric? Remove the bobbin case from the machine and check for thread wrapped somewhere. If you are not able to find an answer on your own, then it's probably best to take it for service.
Janome MC10000 Warning Machine Wont Sew
Jan 28, 2018 | Janome Sewing Machines
Janome 10000 - I get a warning message and the machine quits. I've had it to a repair person 4 times
If you've had it in for repair four times, then the technician is not doing a good job. Take it back and insist it be fixed... talk to the manager and relay your dissatisfaction with the service. OR ask for a refund and take it to a reliable Janome technician.
You don't mention the error message, so it is very difficult to try to assist.
Oct 22, 2016 | Janome Memory Craft 10000
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
I would replace the needle anyway. It's hard to tell if one is bent or not.
Remove your feed dog/needle plate and the bobbin cover. Take out your bobbin and bobbin carrier.
Get out a magnifying glass and really examine. Look for thread ends in between moving parts.
Also check the thread pathways. Especially where the take up lever is hidden. I've heard of some ladies finding threads snarled up in that area which caused problems like this.
Good luck. If all else fails take it in for repair.
Nov 04, 2012 | Janome Sewing Machines
The bobbin seems to be stuck and will not move...all it's doing is 'eating' the thread...what do i do? Thanks
Can you get the bobbin out of the bobbin holder? unplug the machine, then remove the needle plate, needle and pressure foot. Now can you get the bobbin out? It is possible that the bobbin holder has moved in the rotary hook, they can jump sometimes as held in by a magnet.
Check out your manual for instructions to remove the bobbin holder, it should show you how to take it out, and then clean under it, there is possibly thread caught in this area causing the malfunction.
You may find turning the fly wheel a little to turn the hook will help to free up the holder and get it out.
Here is image from my Janome 6500 manual, it should be similar for your MC.
So clean out the underneat of the bobbin holder, then reinsert it, and reassemble, thread and test. If this doens't sort the problem, then time to drive it to the Janome shop.
May 23, 2011 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
111 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
