Question about Kitchen Ranges
Kenmore range broiler burns orange not blue and leake gas
Brand new gas range leakd gas from the oven ahd the broiler flame is orange. when a range is installed what should i see the installer doing to know the installation is being done correctly. should they use a level? should they turn on the burners? what should i be asking them?
    Sergeant:
    Champion:
  • 404 Answers
Probally wrong gas pressure
Posted on Jan 05, 2009
  • 28 Answers
The only real important thing is blue flame with a orange tip,
also ranges have different nozzles for Natural Gas (NG) or propane(LPG)
he can check for leaks with soapy water at the flex line connection
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
New kenmore gas range 790.7433 converted to lp and oven flames are way too high and produce lots of soot...how fix?
Do the rangetop burners act OK, Brenda? It's just the oven that's causing a problem?
Go back to the oven burner, right where you installed the new orifice. That orifice should fit inside an air mixture tube, probably stainless steel, leading to the burner itself. Right where the orifice fits into it will be some means of adjusting the air mixture - a sliding window of some sort, whether flat or round. You'll need to loosen the screw holding it in place (DO NOT remove the screw, only loosen it) and turn it so the air opening is larger. Right now you're getting too "rich" a mixture, too much propane & not enough air. Before you close it all up, try the oven again - see if your adjustment worked correctly. If not, adjust it again - this is a trial-and-error process, and it's different for every different altitude and climate.
At some setting, you'll get a nice blue flame with very little orange in it. If you live in a very high humidity area, you'll have much more orange color than people who live where it's very dry, but the flame should at least be MOSTLY blue, and should never be sooty.
Aug 01, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Broiler flame becomes weak
check lower broiler for clogs - spider webs etc
Jul 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
When oven was 1-year old, the lower oven started making a noise that sounded like a blow torch, usually after being on for a little while. It was (after many service calls) repaired by replacing the...
Hi Nancy
I have to ask you a couple of questions. Is the range set up for LP or Natural gas? Blow-tourch sounds are normally caused by to much air going into the burner. If you can look at the burner safely the flames should burn just out of the burner. If the flames are way off the burner the air adjustment is way off or you range is set for the wrong gas. Are your top burners OK?
Sep 13, 2010 | Maytag Kitchen Ranges
The oven flame comes into the oven around the oven bake cover and all burners and broiler have a perfect flame. this is a brand new oven
Are you on natural gas or propane? If you are on propane did you have it converted form natural gas. Due to the difference in orface size you will be getting more gas flow then needed. If it was converted you need to contact the store and advise them it has a possible gas valve problem.
Jun 10, 2010 | Amana ARGS7650SS Gas Kitchen Range
My oven burns with a yellow/orange flame How do I adjust it to burn with a blue flame
Sound like the igniter is not reaching the correct amp draw, so it is not opening the gas valve all the way. Watch this video on troubleshooting a gas oven. www.appliancehelponline.com/servicemanual.html
Mar 03, 2010 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Oven Flame
Hi still under warrenty get who sold this to you to come back and fix it
Feb 21, 2010 | Kenmore 71312 / 71319 Gas Range
Gas range converted to LP gas huge flame in oven
was the injectors converted in both and was the regulator converted
Jan 21, 2010 | Kenmore 78530 / 78531 Gas Kitchen Range
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 06, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
479 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
