Question about ASUS P4B533-VM Motherboard
Windows will start,unspecified changes to system configuration
  • ASUS Master
  • 27,725 Answers
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
Posted on Nov 06, 2012
Power connection to computer came out during shutdown yesterday. Today, turning on, it will not boot up.
You are going to need a clean boot up disk. You will have to get one mailed to you or you will have to use another computer to download one. This will get you back into a point that you can do a windows restore. This is going to get rid of all programs and start you fresh. I do, however, feel that you disk drive is going out or already shot. You should do a Chkdsk on it. (check disk). This will tell you if it is a hard drive error or not.
Jan 09, 2015 | Computers & Internet
What is error code Ox48f and how do I fix it?
Make, model and OS of laptop please.
Sep 25, 2014 | Computers & Internet
What is your OS and laptop?
Hi i need to upgrade my old pc . i whant to buy a graphic card to play all the new games 2011 but i dont know what g card to buy. my motherboard it is :Mainboard >>> > Manufacturer :...
if you have a old PC then upgrading the graphics card alone will not get your computer up to date to play 2011 games, you might need to buy a whole new 2011 computer. Go online and do a system requirement test of the game you are willing to download or buy and play.
May 09, 2011 | Computers & Internet
Cursor lockup
This just because that there are too many services running in the background of the Operating system
All you need to do is to manually disable maximum of them and disable all the startup Items
Here is how you can do that the easy way
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Microsoft Windows XP Home Edition
Shutdown
Aug 14, 2008 | Dell Dimension 8200 PC Desktop
Strange problem about WBR 1310
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then got to Startup click Disable All and then Apply and then click OK..
Aug 11, 2008 | D-Link 802.11g Wireless Router WBR-1310...
How can i fix system configuration error
Please try to put little more explnation
or try this
Click Start button, and select Run or press windows key + R
in the Run dialog box type 'msconfig' and press enter
In the System Configuration Utility dialog box, select Startup and uncheck the unwanted programs from the start up list.
Select the Srvices tab and you can change the configuration changes here. Be sure not to uncheck anything necessary for the windows to boot.
hope this may solve your problem
Rabby
Jun 15, 2008 | Gateway Computers & Internet
ASUS P4B533-VM Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
