Question about Brother Office Equipment & Supplies
How can I get my Brother mfc 7360 to print pcl6
SOURCE:
dj_relly999
  • 4070 Answers
SOURCE: Black not printing on a Brother MFC-290C
in the printer display try head cleaning option, there must be something blocking the cartridge. hope this helps
Posted on Jul 17, 2009
pineworks
  • 4345 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
pineworks
  • 4345 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Posted on Mar 02, 2010
sylvestermel
SOURCE: Brother MFC 8890DW making Squeaking noise duplex printing
brother MFC 8890 how to replace laser unit
Posted on Apr 05, 2010
  • 7 Answers
SOURCE: my brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Posted on Jun 13, 2010
Error ef brother mfc 7360
Irregular power supply is detected, replace LV PSU or Main PCB assy
Oct 19, 2015 | Brother Office Equipment & Supplies
Self diagnostic will automatically restart within 15 minutes
Check manual or tech support. Maybe youtube has video.
Mar 17, 2015 | Brother Mfc-7360
How to repair head laser brother 7360
you do not repair them-- just replace
you can reset the error code if needed
Feb 16, 2015 | Brother MFC 7360N - Multifunction fax /...
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
My MFC-7360 says NO PAPER, but there is paper.
Most probabply will also say Please put paper in the MP tray ?
Sep 23, 2014 | Brother MFC 7360N - Multifunction fax /...
How to reset brother j125 printer's ink absorber full
Go To Below official brother Printer Page For Your problem http://forum.testcopy.net/threads/how-to-reset-toner-cartridge-reset-counter-for-brother-mfc-7360-printer.1915/ Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
May 04, 2014 | Brother DCP-J125 Inkjet Multifunction...
Outlook won't print to Brother MFC7360N AllInOne Laser Printer
Must be set on Brother MFC-7360N series. Set on PC-FAX will not print with all programs, as it is printing with an output through the fax. Go to control panel, select devices, printers to change to pc-7360 series. This should print on all programs.
Mar 17, 2014 | Brother HL-5240 Laser Printer
644 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
