Question about Allied Telesyn AT WA1104G Wireless Router (ATWA1104G10)
Cannot connect the wireless router
I've already plug the cable, and i trying to access the control panel, i cannot access it.
  • 192 Answers
You will need to know thr router ip adress enter it in the internet browser and after that it may ask you for a user name and password. I hope this solves your proble.
Posted on Jan 05, 2009
  • Michael Ward Jan 05, 2009
    you welcom just rate the solusion
I can't connect to the internet wirelessly. i don't think my linksys router is working
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 29, 2012 | Linksys Computers & Internet
Tip
Hi, I want to use the LINSYS Router as an alternate wireless acces point. I´ve...
'I've forgotten the router password,' is a common problem. But first, which password do you need?
  1. If you want to login to your router, to view or change settings - you need the router login password.
  2. If you want to connect (say) a new laptop to your wireless internet connection – you need the network key. This is the encryption key used to secure your wireless signal. Windows asks for this key when you try to connect.
Here’s a rough guide to what to do in each case. For detailed instructions, check your manual. If you can't find a manual, follow the tip How To Find A Router Manual. (NB: You don't have to read the whole manual - just check a few details, as described in the tip).
1) Retrieving a lost network key - so you can connect (say) a new laptop to your wireless network:
i) Login to your router. Do this by entering http://192.168.0.1 or whatever is correct for your model, into a web browser. Enter your router username and/or password at the prompt.
If you don’t have these, see Step 2, ‘Retrieving a lost router password’.
ii) In the screen that you see, go to the section headed Wireless, Security, or similar. Every router is different, so you may have to hunt around. Key words to look for are Security, Wireless Settings, Encryption, WPA, (or WEP).
Your network key will be here. It might be labelled PSK, pre-shared key, WPA or WEP key, WPA-PSK etc – but that’s the one you need. Now you should be able to connect to your wireless network.
Tip: Write the network key on a label, and stick it to your router.
2) Retrieving a lost router username/password- so you can login to your router, to view or change settings:
i) First, see if there is a label on the base of your router, showing the correct username and password.
ii) Otherwise, try the defaults and see if they work. Common default usernames are admin, or blank (ie type nothing, just leave blank).
Some common default passwords are password, admin, 1234, sky (for UK Sky users), or blank (no password). Check your manual for this, or try a Google search. It’s important that you find the correct default password for your router.
iii) Defaults don’t work? You will have to resort to a hard reset.
Beware. If you perform a hard reset, your router will be back at factory defaults. Your router login password will then be the default, BUT you will normally lose all your router settings. If you have a combined modem/router you will also lose your internet connection, until you have set up your router again.
If you are very concerned about this, ask the person who set up your router to help you.
Otherwise, you can do it yourself . Every router and ISP is different, but if you have your ISP login details and your manual (see How To Find a Router Manual ) - you should be OK.
Your ISP’s website may also have info which will help you - why not take a look. Similarly, your router manufacturer’s website may offer easy install software, and setup tips, if you need them. Print off any online information you need before performing the reset.
iv) To reset - ensure you have a wired (ethernet) connection to your router, and that it is switched on. Find the router reset button, which may be an unmarked pinhole, often on the back of the router. Press and hold down the reset button as long as it takes to reset the router. This is typically 10 seconds or so (check the manual).
v) You can now use your default password to login to the router, and set up your details afresh.
I hope this tip helps you. Losing a password is a pain, and we've all done it. But - armed with your router manual - you will soon be up and running again.
All information is offered as is, without warranty. If you choose to use it, it is completely at your own risk. If you are in doubt, consult a local professional. Thanks to all Fixya contributors who helped with this tip. Updated Dec 09.
on Feb 20, 2009 | NetGear DG834G Router
How to retrieve password from wireless access point router zyxel -570u
Initial Set-Up
Plug your wireless router into the cable connection in your wall. Plug the connection cord into the "WAN" port on the router. Plug the router's power source into the wall and turn the router on. Connect your wireless access point to your router by pushing one end of an Ethernet cord into the WAP. Push the other end of the Ethernet cord into the "LAN" port on the router. The WAP connects your wireless devices to your router.
Connect your laptop or computer to the WAP. Click the "Start" button on your computer and then click "Control Panel." Click "Network and Internet" and then select "Network and Sharing Center." The "Network and Sharing Center" window opens.
Click "Set up a wireless router or access point." Click the "Next" button.
Follow the prompts to create a wireless pass phrase or security key. Write the key down in a safe location to ensure access later, if required.
Aug 30, 2011 | Zyxel ZyAIR G-570U - Wireless access point...
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Jul 26, 2011 | Linksys WRT160N Wireless Router
How do i hook up a wireless router to a cable router
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Dec 30, 2010 | Linksys Wireless-G WRT54G Router
How do I secure my wireless connection
Access the router's built-in web-server, and run the "Wireless Network Setup Wizard". Change the 'SSID' ("Network ID") and change the router's password.
Dec 05, 2009 | Axsion Axion Actiontec Wireless-Ready DSL...
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Wireless internet connection
Hi, to connect to wireless you need to access your wireless router, by connecting it with a cable and access router control panel.
To access router control panel you need to type router IP number on Internet Explorer bar, once the router is connected, then enter user ID and Password.
Once you are in router control panel go to wireless settings and set up your wireless.
You find router IP and user/password on the router manual, follow instructions on route user manual to connect to router control panel.
If you need more help you can call the support number listed on the router manual, or get a chat on Fixya.
regards
Sep 11, 2008 | NetGear WGR614 Wireless Router
I need to hook up and start using a wireless router, can i get some help starting?
hi licking;
what type of wireless router are you using? a linksys? or a dlink?
do you have color coded cables?
try this:
from your modem(the box given to you by your isp), connect a cable from your modem LAN port to the WAN port of your wireless router.
If your going to connect a pc wired to your wireless router, you can connect a cable from your wireless router LAN port to your lan card of your PC.
give more details and ill be happy to help you. :)
Jun 19, 2008 | Computers & Internet
Signifcant delay when printing
Your post does not mention all IP addresses in use, and which devices use wireless. That information would be helpful.
Is it possible that you are getting an IP address from a router for your internet access, then when you try to talk to your print server it may be trying to assign an ip address too.
(Sometimes a wired computer also has wireless enabled, which can cause an issue when one ip address has already been received on the wired connection and a wireless connection is also trying to connect.)
Mar 29, 2008 | NetGear PS121 Print Server
Open Questions:
Allied Telesyn AT WA1104G Wireless Router (ATWA1104G10) Logo
171 people viewed this question
Top Allied Telesyn Computers & Internet Experts
Prashant M
Prashant M
Are you an Allied Telesyn Computer and Internet Expert? Answer questions, earn points and help others
