I have an asus intel pc the USB ports are freezing the mouse cursor so to stop the pc I have to hold the button down and turn it off the wrong way. I have moved the mouse to other ports it works for ten or fifteen minutesthen freezes again. I'm sick of it, it can't be the mouse it's got to be the ports????? what do you think????
  • 3 more comments
  • gum_bus Jan 05, 2009
    The advice was good but he didn't tell me how to fix it, he said it was a hardware problem but how do I fix it. The pc is only new it should not have happened, anyway can you help me?
    I'm sorry I'm not good with pcs what is a USB card where do I look for it cause I haven't got a clue can you help?
    If the USB port is bad where do I find it?
    I meant to say where would I find the USB port card?
    you still have not answered my question, where do i find the usb port card and what does it look like?
  • 365 Answers
Is there any drivers for the USB drivers which you have mentioned.the overslow may b also due to some virus attack.try to check for it also.thank you
Posted on Jan 05, 2009
    Guru:
  • 859 Answers
Well now, if you are seeing this response you are in deep trouble indeed. The problem is the mouse, not your usb ports. you should never have this trouble from a mouse... period.
the people asking, slash begging for a rating should be despised for doing so. The answer speaks for itself, there is never a need to ask or a rating. It works or it doesn't.
Worldvet
    Scholar:
  • 142 Answers
Dear sir
for this solucation u need to chek some of settings like first of all u need to chek Earthing of yr pc is ok or not then boot yr pc in safe mode "pressing F8 key" and try to chek it..or as per yr setfication plug yr mouse to other pc or laptop to conform it's... it's help u..:)
thanks
please vote
jo_chinmay
  • Chinmay Joshi
    Chinmay Joshi Jan 06, 2009
    mr. worldvet tells is righte it's yr mouse problem just chek it's working or not..?
  • 495 Answers
A USB card composes of a USB host controller and several USB ports that allow you to install a wide range of USB peripherals. USB cards come in two favors: USB PCI card, and USB CardBus. The latter is only made for fairly old laptop computers. USB PCI cards are designed solely for desktop computers.
    President:
  • 1,952 Answers
I think still warranty time you tell service center change the mouse and clear the hardware problem replace the usb cart cost of free
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Jan 05, 2009
    The front of the case has two USB outlets
    First thing to do is to swap the lead from the front USB slot onto the other connector on the mobo.
    This will tell you if it is a mobo problem or if your new lead is duff.
    If it points to the mobo. check your BIOS to ensure that the mobo connectors are enabled.
    If you tried multiple different USB devices on that port and none of
    them worked we can say w/ a high level of confidence that the USB port
    is probably bad. Have you tried connecting the camera to a different
    USB port on the computer? Most machines these days come w/ 2-4 ports
    on the back and a couple in the front. See if one of the other ports
    work.
    Connect two devices directly with one USB cable by plugging each end
    into a USB port. If using a USB hub, plug a separate cable into each
    device and connect them to the hub individually.
    You may plug cables into a USB port at any time regardless of
    whether the devices involved are powered on or off. However, do not
    remove cables from a USB port arbitrarily, as this can lose or corrupt
    data. Follow instructions provided with your equipment before
    unplugging USB cables.
    Many PCs feature more than one USB port, but do not plug both
    ends of a cable into the same device, as this can cause electrical
    damage.
  • 565 Answers
Try to reinstall drivers, also try other mouse if other mouse work well then is the mouse demaged. if not then the problem can be with the usb drivers or the port is demaged. the drivers update u can download from asustek homepage asustek is the asus brand developer.
If it helped rate fixya if need more help u free to ask
    Sergeant:
    Champion:
  • 239 Answers
Try another mouse see what hapens
    Sergeant:
    Champion:
  • 338 Answers
Try redownloading the driver for the mouse and reinstalling it. if it is a mouse that you bought after the fact and it came with an installation cd use that. it sounds like the driver for the mouse has become corrupted.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A simple method of determining which is at fault is to test/use the mouse in another PC and/or use another USB mouse in the Intel PC.
Almost always, it is a driver issue since the mouse (even if USB/HID-compliant consumer control device) is a basic hardware component.
Of course a remote possibility is a possible virus using much of the resources hence making the computer sluggish and is seen as a slowdown of the mouse/cursor activity.
Good luck and Thank you for using FixYa.
  • 6,487 Answers
What you can try here is to use a different usb mouse to check if it will still have the same problem if possible because if the other usb mouse work fine so its the mouse but if the other mouse still have teh same problem USB port is bad...
    Sergeant:
    Novelist:
  • 326 Answers
Jusr repace the usb card in which the ports are.also try to remove and reinsert the usb card.as if the card moves slightly this happens.
just try to check out is it connected firmly in the socket.
    Genius:
  • 1,550 Answers
Yes you are correct it is port . It has nothing to do with mouse . Your port is damaged thats why mouse is freezing frequently . It is hardware fault .
Mouse Cursor
Check in power options and the CMOS settings for anything USB related and disable anything that would cause USB to sleep or power save, make sure legacy USB is on, then check your Windows power options for the same, disable anything to do with USB power saving. If all else fails, go to ASUS website and go to the drivers and downloads section, download the latest BIOS revision for your model and update your BIOS.
Dec 20, 2013 | ASUS ET2300INTI All-in-one PC
Tip
Mouse pointer with keyboard keys
<span><b>You can control your mouse pointer with keyboard keys in all windows versions. When your mouse stops working, you can enable this keyboard feature to complete your important work. This keyboard mouse can performs all tasks same like a normal mouse.</b><br /><b>Follow the given steps to activate the keyboard mouse:</b><br /><b><br />To edit this feature, first you should log onto your computer with administrative rights.<br />To activate this feature, press Alt+Shift+NumLock keys at once and you will receive a small MouseKey box.<br />To keep MouseKeys on, click on Ok button or click on cancel button to cancel MouseKeys box.<br />Click on Settings button, if you want to adjust the mouse cursor detail settings.<br />Here a new dialog box will appear with the title Settings for MouseKeys", now you can manage all mouse settings for example mouse cursor speed, acceleration and some other features.<br />Now using Numeric keypad, you can move your mouse pointer. The controls are:<br />*<br />1,2,3,4,6,7,8 and 9 keys are used to move the mouse cursor into different directions.<br />*<br />Key 5 is used as mouse click button.<br />*<br />Insert key used to hold down mouse button.<br />*<br />+ Sign used to double click on any object.<br />*<br />Delete button used to release the mouse.<br />*<br />Click on NumLock button to disable this keyboard mouse feature</b></span>
on Apr 04, 2011 | Computers & Internet
The microsoft wireless mouse stopped working after a power failure. I get a message that says the USB device is not there. But I cannot navigate my computer w/o the mouse
The Microsoft wireless mouse comes with a wireless receiver, right? Before you do anything, the first thing that you can try is to replace the batteries with fresh ones.
If same problem occur, try to connect the wireless receiver into different USB ports of the computer. Then check if your wireless receiver and mouse has a connect button. If it does have connect buttons, briefly press the connect button on the receiver, then hold down the connect button on the mouse for 5 seconds. Then release the connect buttons.
If you get the same problem, hold down both connect buttons (receiver and mouse) at the same time for 5 seconds.
Last, try to connect the wireless receiver into different computer. If you get the same problem, send the receiver and mouse to the manufacturer for repair.
Thank you and good luck!
Jun 15, 2010 | HP Computers & Internet
Asus CS5111 keyboard stopped working
Try taking the batteries out of the mouse and let the receiver find the keyboard first, then once the keyboard is found put batteries back in mouse and let the receiver find the mouse.
Nov 21, 2009 | ASUS Computers & Internet
Cursor only works for 5 min., then it stops.
there may be a mouse port problem try checking ur ps/2 port by a loopback plug.if not replace ur mouse.
Apr 18, 2009 | Computers & Internet
Wireless keyboard and mouse stopped working
try to replace the battery on mouse and the keyboard with new battery put you mouse and keyboard close to the computer, see what happen,
Mar 29, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Simple dear first of replace the battery with new one and than press the connect button on sensor. or if u r not able to get out than change the polarity of the battery by changing there position.
Jan 29, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
My mouse has stopped working on my acer laptop
Do you mean the touchpad or a USB mouse? if its a usb mouse try another usb port, is it wireless? if its wireless check the battery.
if its the touchpad it may be turned off, to turn it on hold down the blue FN button and look at the F1 to F12 keys, one of them has a touchpad icon and it will disable and enable the touch pad, don't worry if your not sure try them all if you wish. You will probably learn something new while your doing it :-)
Dec 28, 2008 | Computers & Internet
My mouse has a cursor but the cursor won't move when & where I want it to. Have switched to a different mouse & it does the same thing. What is wrong?
One thing you can try is you are currently using a PS/2 mouse (one with pins and whatnot), try a USB mouse. If that doesn't work then you know there's something wrong with your Operating system. If it does, then there's something wrong with the PS/2 mouse port
Jul 27, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
