Question about Motorola Mobility RAZR V3i Cellular Phone
Charger of my v3i unable to charge.
When connected to ac output, it does not charge, green light does not turn on. when connected to computer it charges with a display.. that hardware problem..then goes off and on thre to four times and then starts charging...
  • 28 Answers
Probably a bad charger try someone else's I had this happen once from the many phones i had (that and the dog ate the wire on another)
Posted on Jan 05, 2009
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Battery is not charging
Does it NEED a charge? The camera can get screwed up. It has to turn ON to charge. For the most reliable charge do NOT use the computer. I use my computer to 'top off' the batteries. If they are really dead I use wall charger.
Jul 22, 2017 | Nikon S9200
Toughbook will not start, we have it plugged into the wall and when we switch it on the battery light turns red and nothing else happens? Thanks, Brad M.
> battery light turns RED
For Panasonic computers, that indicates that the battery is almost completely discharged (it's YELLOW while charging, and GREEN while fully-charged).
So, my guess is that your AC adapter has failed,
and that your battery needs recharging.
Or, the socket where the AC adapter connects into your computer is damaged, such that no power from the AC adapter is reaching the computer.
Take a "MultiMeter" and check the voltage & amperage output-level from your AC charger. If "zero", go onto eBay and search on the part-number, to find a compatible replacement part.
Oct 11, 2010 | Panasonic Toughbook 28 Notebook
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Try a USB plug o the back of the computer. These plugs have more power available.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. Check you screensaver and power settings.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
Next try and reset the player. Resetting the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Once it is back working, go to the SanDisk support site and get the updater program and update your firmware.
Jul 15, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Recharging - indicator lights when complete
When the green light stays on that means the battery is fully charged. The correct charger for that light is a Class 2 Transformer
Model: KA12D120030042U It has a output of 12VDC at 300 mA
May 29, 2010 | Vector 2M Pwr Rch Spotlight
Xantrex Inverter/Charger has no AC output
Checking AC Output
1. After the battery voltage and connections have been checked, disconnect the inverter.s AC output wires from
the power distribution system and connect a light to the AC output of the inverter/charger.
2. Disconnect the remote panel to eliminate it as a possible problem.
3. Turn the inverter ON using the power switch on the front panel of the inverter. The 100-watt light should
illuminate. Measure the voltage at the AC output wires using the multimeter. The reading should be 114.126
VAC or approximately 230 VAC if the unit is an international model. If the light does not illuminate, there is
a problem with the inverter. Contact Xantrex technical support.
May 21, 2010 | Kitchen Ranges
Unable to charge the 3100. If charged via car
the Magellan Maestro can not be charged using the USB connection.
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you can get it repaired here
or buy the port here
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Battery problem...
This issue can be caused by any of the below possibilities. 1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Oct 14, 2008 | Dell Inspiron 6000 Notebook
V3I, light turns on and then goes off. Unable to charge.
The phone usb needs to be either clean or replaced so take them to a repair center and have them service.
Oct 15, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
83 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
