Question about Western Digital Caviar SE WD1600AAJS 160 GB SATA Hard Drive
Got a virus that took over can't run any clean up or virus scan
Virus took over virus protection (avast) then speard and took over everything even restore says I am not authorized to run restore
  • rthomas986 Jan 05, 2009
    already tried that want let anything run from cd drive
  • 28 Answers
You may have to run the system recovery cd/windows setup cd and reset everything
formatting the drive looses all of your data, if you have a windows cd you may be able to do a revovery but this dosen't erase the virus
Posted on Jan 05, 2009
Formating remove virus
first off you have a choice you can either run virus scan to attempt to remove it from with in safe mode
format the HDD assuming it isn't your primary OS drive
or reinstall the whole OS
we will start with safe mode
so whilst the pc is still in start up (POST) rapidly press f8
this will take you through to a start up menu choose safe mode at the top.
once booted up log in and run antivirus software such as bitdefender/avast/avg and others. I recommend avast (personal preference) if nothing Is found look for more in depth for a better anti virus program.
formatting will technically remove a virus from a HDD but if you format your OS your screwed and it is unlikely that a virus will install itself to your second drive so ignore this. (don't even attempt to format)
this is a last resort if you cant solve it.
borrow or create a live cd/dvd/usb OS boot the computer into this and then install the OS if you are using windows, use your recovery disk that no one makes and if you didn't make one contact your laptop/PC manufacturer as they should have one for a fee
Jan 12, 2014 | Transcend StoreJet Computers & Internet
Autorun
Remove Computer Virus
Remove Computer Autorun Virus
When I copy any data from removable disk A Folder auto copy in every folder
1.You should install a update antivirus and scan all drive .[antivirus like avast / Symantec etc.]
2.Your problem must be solve.100%
May 10, 2013 | PNY 8GB HP c500w USB Drive
How to remove virus on Toshiba external hard drive
I assume you don't have an antivirus program installed. Go here:
http://majorgeeks.com/download.php?id=29&sort=7
Download, install and run these FREE apps and any other apps you feel
might help:
1. Avira Antivirus or Avast Antivirus
2. Kaspersky Virus Removal Tool
3. Malwarebytes Anti-Malware
MalwareBytes is here:
http://majorgeeks.com/download.php?det=5756
Just make sure to select your external drive so it's included in the scan.
May 22, 2012 | Computers & Internet
To a Hp System ( pentium 4 ) i put a pen drive. Cpu detects and try to install by itself during the process cpu gets Stucked
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
There are many things that might cause your PC to run slowly. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
An excellent free utility for overall system maintenance is Advanced System Care Free ( http://download.cnet.com/advanced-systemcare-free/3000-2086_4-10407614 .html ). I use this utility on a regular basis.
You should always run anti-virus software. There are several very good, free, anti-virus products available. One good source to read editor and user reviews, and safely download anti-virus software, is http://download.cnet.com -- search for free antivirus software. In addition to the reviews, you can see how many people are downloading the software, which is another good indicator of how popular it is.
I have used AVG Free ( http://download.cnet.com/avg-anti-virus-free/3000-2239_4-10320142.html ) , and Avast Free ( http://download.cnet.com/avast-free-antivirus/3000-2239_4-10019223.htm l ). Both are very good, and completely free. At present I am using Avast on all of my home computers.
I have heard good things about Avira AntiVir Free ( http://download.cnet.com/Avira-AntiVir-Personal-Free-Antivirus/3000-22 39_4-10322935.html ), and it has good ratings, but I have not personally tried it.
In addition to Avast or one of the other free anti-virus software packages, I also run Ad-Aware ( http://download.cnet.com/ad-aware-free-internet/3000-8022_4-10045910.h tml ). Ad-Aware is a free anti-malware, anti-spyware package.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 07, 2011 | Computers & Internet
C drive is always in red color.even clean all
This may mean that there could be too many files on your hard drive or there is a virus on your system so get anti-virus (I recommend Norton Internet Security) if you don't have any and run a scan right away.
May 07, 2010 | Computers & Internet
I want avast 5.0 update can u tell how can i download it urgent
if u already have an older version of avast... just doubli click on the avast ball on your try... an avast window should pop-up... then click on maintenance button... there you can see the update button,, for the virus definition and for the anti virus proram.... hope this would help,,...
Mar 02, 2010 | Avastor HDX-400 80 GB FireWire 400 (1394a)...
How to remove trojan horse virus in usb 2gb
Connect USB drive to USB port.When icons appears in My Computer, right click on it. A popup menu appears showing option for virus scan.By clicking on it scan the entire drive.
But dont ever open that USB drive, if there is a possible trojan. because when you will open that USB drive, the trojan will be copied into your hard drive automatically.
Best way to remove trojan is to completely format your USB drive.
Oct 29, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Windows cannot verify the digital signature for this file. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from...
Try booting into safe mode with networking and see if you can get into the disk, if that works, then run a virus scan on the whole thing.
Also I recommend downloading and installing AVAST! select all settings to their highest level, then also run a "BOOT TIME" scan, this should clear out any viruses you will be able to remove yourself.
If it is more serious than this, you may need to bring it to a tech or call one in, if you have more info or require more info let me know, I CAN solve this problem.
Jim
Aug 05, 2009 | Acomdata 500GB External Firewire HD 500 GB...
USD HD folder Showing empty even though the HD shows as 96% full.
Sir,
This is the problem of worm, virus. Now-a-days virus is disturbing entire system. U must update your anti-virus, Purchase a full version including total internet protection, update the OS(operating System), Full Scan the system. it must be cleared
Thanks
Good Luck
Jul 24, 2009 | Western Digital My Book Essential 1TB...
I cannot format my pen drive as there is some virus in it
  • You must have an updated antivirus to scan your pen drive. I recommend you to use full version of avg 8 or avast. It will surely delete those viruses on your system and so as in your pen drive.
  • Or you can format your drive with this steps:
    1. Go to start menu
    2. Click Run and type cmd
    ==A command prompt shows.==
    3. Type cd\
    4. Type format x:
    5. Press Enter key
    6. When done type exit
  • Please vote... your vote will highly be appreciated. Thanks in advance...
Dec 24, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Western Digital Caviar  SE WD1600AAJS 160 GB SATA Hard Drive Logo
69 people viewed this question
Top Western Digital Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
