Question about Husqvarna Rose
Feed dog wont come up high enough to sew
I put the Feed Dog down and now wont come back up high enough to sew.
  • Bill Williams
    Bill Williams Jul 08, 2016
    I had the same problem. Feed dogs would not come up high enough to pull material through. What I discovered was, although I would clean the bobbin area, I never took the foot off to get a good look. What I discovered was years of built up lint at the rear area of the feed dogs. It was packed in there pretty tight. After cleaning all the lint out with tweezers the dogs worked just like they were supposed to.
  • Husqvarna Master
  • 7,365 Answers
Try this and see if it will work for you
When you set the switch for the feed dogs in the up position
turn the handwheel 1 complete revolution and see if
they come up
Posted on Nov 06, 2012
  • Nichole
    Nichole Jan 19, 2015
    This worked. Thank you for making my day!
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
SOURCE: Viking Sewing Machine Model 6360
There is a white button on the front of the machine to the right - it has likely been pressed in to drop the feed. Press it in and release so the button comes out - that should solve the problem.
Posted on Dec 11, 2008
  • 9 Answers
SOURCE: Husqvarna Designer 1 won't sew...feed dog won't come up
Either the feed drop is engaged or it may not be releasing due to being stuck because of an oiling issue. Let me know if you've checked this as I have one around to reference as well.
Posted on Feb 21, 2009
SOURCE: Feed dog won't come back up after embroidery is
I didn't "get" the "full rotation" and fought with my new-to-me Viking Rose 605 for an hour to no avail, eventually installing and uninstalling the embroidery hoop. Then, I slid off the bobbin cover AND the feed dog cover, poked the feed dogs with my tweezer, and they released.
Posted on Sep 07, 2009
  • 371 Answers
SOURCE: Thread balls up underneath my feed dog when
Could be needle/hook timing. With machine off do the following to check timing -
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area and thread cutter area, removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew without thread balling up, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Posted on Sep 26, 2009
The feed dog is up but has stopped feeding
Are the feed dogs moving at all--like moving toward the back of the machine, dropping down below the needle plate, moving forward, rising, and then moving toward the back of the machine? Make sure the stitch length is set high enough to actually move the fabric--not set at zero or near zero. If the feed dogs stay below the needle plate, then most likely they have been dropped for darning.
If the feed dogs are frozen, not moving, and it is an older mechanical machine, they may be seized due to old oil.
Wheel on right side that controls the needle up and down is very tight...
Or, the feed dog mechanism is broken.
Sep 01, 2017 | Sewing Machines
Hi. I have a Singer 132k6. The feed dog goes up and down, but not back and forwards. Any suggestions?
Check that the stitch length is set high enough to actually advance the fabric. Otherwise, the feed dogs may be seized or defective.
Feb 14, 2017 | Singer Sewing Machines
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Dog feet seem as if they are not raising high enough to grab material and move it back. It their a simple adjustment?
It could be that your stitch length is not long enough to sew in a forward direction. Embroidery/Sewing machines have a feed dog switch to raise and lower for sewing or embroidery.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 28, 2014 | Sewing Machines
My feed dogs keep coming up when using a hoop doing embroidery what can be the cause?
sounds like there is something wrong with the feed dogs or the feed
dog lever could be broken,, they need to be checked
Jan 24, 2013 | Brother InnovIs 4000D Computerized Sewing...
I put the feed dogs down and now they won't go back up, what do I do now?
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Feb 11, 2012 | Baby Lock Ellure
Yes we know . bit they are down they dont seem to be high enough up .not pulling fabric through .
Remove the needle plate and check for lint build up between the feed dog teeth. Lint will build up and prevent the feed dogs from coming up all the way. I them still don't come up high enough, then they will have to be adjusted.
Apr 25, 2011 | Janome Memory Craft 9000 Computerized...
Feed Dogs Kenmore 158.19802
I think the feed dog lever needs to be positioned on the right.
Sep 15, 2008 | Sewing Machines
Sewing Machines Logo
292 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
