Question about Bosch Vacuum power supply pump mercedes benz 0 132 006 345
How to Choose a Vacuum Packaging Machine?
When purchasing vacuum packaging machine, due to there are too much alternative models, people always become confused that how to choose a suitable vacuum packing equipment? Following analysis is conductive to your choice.
1.To determine the nature of products.
Different vacuum packaging machines are suitable for different products, some products with special properties, such as fluid, powder, granular and lump objects, etc., should not only satisfy the vacuum packaging function, but also asked to achieve better effects of vacuum packaging.
2. To select the appropriate vacuum packaging machine models.
Thinking about the function, vacuum packaging machine has many types, including ordinary ones, rolling ones, continuous stretch film ones and small vacuum packaging machine, etc, according to different production, people can select vacuum packaging equipment that fit themselves.
Different functions: Automatic stretch film packaging machine, single or double chamber vacuum packaging machine, automatic vacuum packaging machine, skin packaging machine, cassette vacuum packaging machine, rolling vacuum packaging machine, air switch installed packaging machine.
Different materials: all stainless steel, semi-stainless steel, ordinary steel, plastic spraying.
Different vacuum pumps: domestic special pump, imported vacuum pump, special vacuum pump. Imported pumps are more expensive, domestic pumps are relatively cheap, customers can choose them according to the practical situation.
3. Whether the power supply of workshop is suitable for vacuum packaging machine.
Some vacuum packaging machines apply to 380V power and some are suitable for the 220V power. If the power is too far away from the vacuum packaging machine, longer wires is required, and this situation may cause inadequate voltage, affecting production. Therefore, people should buy vacuum packaging machine according to the power of their factory.
4. Evaluate quality and after-sale service, etc. of vacuum packaging machine and choose cost effective vacuum packing factory, since this will reduce a lot of trouble for use.
5. Before purchasing a vacuum packaging machine, purchaser should consult with manufacturer on parts supply problems, to avoid delay in production caused by the malfunction of vacuum packaging equipment.
Dec 21, 2016 | Vacuums
How to install a belt tensioner adjuster on a 92 mercedes benz 500sl
belt tensioner is on right hand front of engine slacken it off full and use bolt head to turn centre piece until desired tension then lock
Mar 22, 2014 | GE 1992 Mercedes Benz 500SL Instrument...
I can't get replacement bags for my Bosch Premium 1300 W vacuum cleaner.
Greetings from GoVacuum,
Your Bosch Premium canister vacuum cleaner uses Bosch Style P Bags.
We carry 2 different types of Bosch Type G bags for your vacuum cleaner.
We have the genuine Bosch Bags Available for Purchase Here;
Bosch Type P MEGAfilt™ Super TEX Vacuum Cleaner Bags
And also in bulk buy here;
3 Pack Bundle Pack of Bosch Style P Vacuum Cleaner Bags Part #BBZ52AFP2U
And we also carry a generic paper style bag that doesn't filter as well as the cloth Bosch genuine bags, but is suitable if you don't have any breathing issues or allergies in your home. Here are the Bosch generic P bags;
Bosch Type "P" Canister Vacuum Bags Generic
I hope that this information was helpful to you. If this helped you, please be sure to rate this as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of my answer.
Feel free to email me at chris.jones@govacuum.com if you have any questions or need further help with your Bosch canister vacuum.
Thank you so much,
Chris Jones
GoVacuum.com
Feb 22, 2010 | Bosch BSG81313UC Premium Bagged Canister...
Vacuum will no longer turn on. Vacuum bag was
Same problem. I suppose BOSCH dumped these into the market and have chosen to disown them. Support is pitiful and vacuums have also been taken off their website. Too bad, was a nice quiet product for the 2 months it worked. Solution = new, non-BOSCH vacuum.
Oct 04, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
Bosch Formula vacuum cord stuck
You need to take apart the reel. The cord is wound over itself and kinked. Be careful taking apart because if it gets away from you, you will have to wind the spring by hand and it is difficult to do and frustrating.Good luck
Jul 26, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Where can I buy vacuum bags for my Bosch canister model BSG71 UC
Check out Ebay.com
or
http://cgi.ebay.com/GENUINE-BOSCH-TYPE-G-VACUUM-BAGS_W0QQitemZ190296223025QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item190296223025&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Mar 26, 2009 | Bosch BSG71310UC Bagged Canister Vacuum
No motor action when the power is ON
I have the same problem with mine -- precisely the same model BSG 81335UC. It feels like the power button switch isn't working properly.
Dec 31, 2008 | Bosch BSG81360UC Premium Health Guard...
Vacuum will not power on...
your repairman missed the thermal fuse in the motor compartment
Aug 10, 2008 | Bosch BSA2200UC Bagged Canister Vacuum
Bosch Vacuum upright
its a problem with the power switch you can wire nut the wires together but I have been looking for parts myself.
May 20, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
My bosch turbo jet vacuum
open the head. there is a dc 120 v motor with a belt.
check for ac power going in to the rectifier board and dc comming out.
sometimes the black wire breaks inside the motor housing.
it is hard to open and close the motor housing side where the wires run and closing the power head is fun as well.there is a transformer for the light and wires have to be routed just right to close it up.
good luck
Paul G. Canada
May 07, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
Bosch Vacuum power supply pump mercedes benz 0 132 006 345 Logo
26 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
 John
John
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
