Question about HP Pavilion dv6225us Entertainment - Turion 64 X2 TL-50 / 1.6 GHz - RAM 1 GB - HDD 120 GB - DVD RW PC Notebook
Need more memory
Computer is responding slowly. So what type of replacement would I need for the memory module to make it run faster?
  • 564 Answers
PC2-4200 DDR2 SDRAM SODIMMs. maximum memory is 2GB which would be 2x1GB sticks.
I would remove the cover on the bottom of your laptop and remove the memory installed to check the type and size.
Posted on Nov 06, 2012
CAN I REPLACE THE MEMORY WITH A 4 GIG STICK
this will depend on your motherboard
whether you can install a 4 gb module of ram
you will need to select your motherboard from a dropdown list
also on the left will be types of ram ddr2 ddr3...... you will need to select which type you have
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
NON-ECC/Non-parity - Most desktop and laptop computers take NON-ECC or Non-parity memory.
ECC/Parity - ECC or parity modules look for errors in data and are most often found in servers and other mission-critical applications used by large networks and businesses.
Unbuffered - Most PCs and workstations use unbuffered memory which is faster than registered memory.
hope this helps you
Oct 12, 2011 | Computers & Internet
Installed corsair h60 and now the computer switces on but the screen is blank
when installing ram always keep the largest module closest thr CPU central processing unit
it sounds like a compatability issue
you can check the compatability using this memory advisor
Registered/Buffered - Registered or buffered modules delay all information transferred to the module by one clock cycle. This type of memory is primarily used in servers.
Fully buffered - Designed for next-generation servers, features an advanced memory buffer.
CL - CAS (column address strobe) latency, which is the number of clock cycles it takes before data starts to flow after a command is received. Lower CL is faster. Modules with different CL can be mixed on a system, but the system will only run at the highest (slowest) CL.
Component configuration - (For example: 64Meg x 64) Indicates the size of the memory chip components on the module.
Voltage - For example 2.6V. Indicates the power used by the module. The lower the better. Check the glossary and FAQs for more detailed definitions.
hope this helps you
Sep 24, 2011 | EliteGroup A790GXM-A Motherboard
I have a Foxconn n15235 motherboard and i have installed a 2 gig ddr2 memory but it only registers as 1 gig,could you please help...
how many modules compatible are the ram modules the same type/brand some motherboards will not accept more than one type
also make sure the ram modules are securely seated with no dust in the sockets
The purpose of RAM is to allow your CPU faster access to programs. If your CPU had to go to the Hard Drive anytime it wanted a program your computer would run very, very slowly. So for example, when you boot your system up a significant ammount of ram is designated to your devices needed to boot up your operating system video graphics
The primary role of RAM is to copy the operating system in to itself and then load the Operating System so that you can work RAM is only used to run any desktop base applications, such as games, Microsoft Word applications, games such as desktop games and pc games, and browser based so any programs you have loading at start up will be needed by computers RAM
http://majorgeeks.com/download.php?det=1670
Freeware app that defragments and frees up your system's RAM.
Freeware application to free and optimize your computer's RAM (Random Access Memory), resulting in an increase in system performance and productivity. Automatically configures itself for ease of use and also features advanced options and customizability. FreeRAM XP Pro has been designed to be easy to use yet highly customizable by computer novices and experts alike.
hope this helps you
Sep 10, 2011 | Foxconn P4M800P7MA-RS2 Motherboard
We need memory upgrade to 4Gb jn MB GA-4MPSV. What memory module are supported by Transcend, Kingston, Samsung for This MB?
This WEB site details the RAM modules you need and the prices.
http://www.memory-up.com/memory/GigabyteGA-421376.html
Apr 12, 2011 | Computers & Internet
What is the max (RAM) memory the Gateway Tabor 3 Coppermine WS440BX Motherboard will thak. Also memory type please.
After doing some research, I found that you had an Intel motherboard and used a website called www.crucial.com (Crucial is a brand of memory and have some useful tools on their website) These are the specs that came up. You can view the same information at this web address http://www.crucial.com/store/listparts.aspx?model=WS440BX
It also shows the price of the upgrade! Hope you find what you are looking for!
  • 168-pin DIMM Banking: 3 (3 banks of 1)
  • Chipset: Intel 440BX
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 2X
  • Max Component Density: 128Mb
  • Max Unbuffered SDR SDRAM: 384MB
  • Module Types Supported: Unbuffered only
  • SDR SDRAM Frequencies: PC66 and PC100
  • Supported DRAM Types: SDR SDRAM only
  • USB Support: 1.x Compliant
Q: Will my system recognize the maximum upgrade?
A: Possibly How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251.
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: SDRAM memory with support for SDRAM, PC133 speeds. Because SDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible SDR speeds listed below.
Q: How much memory can my computer handle?
A: 384MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No. No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No. Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: No. Your system does not support ECC. Because ECC and non-ECC modules should not be mixed within a system, install the same type of modules that are already in your system.
Aug 04, 2010 | Gateway Computers & Internet
I have a Toshiba 2775XDVD Laptop computer that has a mobile Pentium lll processor featuring Intel speed step technology. It originally came with WIN 98 but I have loaded WinXP on it and changed HDD's. I...
Base from the description of your problem and from the information of your computer this is a sign of old hardware like processor that is definitely getting slow since the unit is already old, you might want to replace that But you can also do the following to increase the processor speed.
Firstly disable all the settings in Start up mode.
this can be done by following instructions:
1)Go to “Run”.
2)type “msconfig” in run.
3)Go to Start up.
4)Disable all startup items except Antivirus.
Jul 19, 2010 | Computers & Internet
Does the acer aspire 5315 2077 require a certain type of memory?
Go to www.crucial.com and click on the scan my system button to see what configuration of Memory Modules are installed on your laptop.
Here are some other details:
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Chipset: Intel 960GML
Drive Form Factor: 2.5"
Drive Interface: SATA
Maximum Memory: 2048MB
Slots: 2 (2 banks of 1)
Standard Memory: 512MB removable
USB Support: 2.x Compliant
A: DDR2 memory with support for DDR2 PC2-5300 speeds.
A: 2048MB.
A: No.
A: Yes.
Jan 14, 2010 | Acer Aspire 5315 Notebook
Installed new memory modules can get to the toshiba post screen
Two ways to approach this.
1. try 1 stick at a time and see if you can boot and the system is working,
2. Download and run memtest to see if you got bad memory.
Apr 02, 2009 | Toshiba V3100 PC Desktop
Dell Dimension 8250 Memory Question
Computer Memory Information Upgrade Questions Troubleshooting Memory Diagram Upgrade Help Buying Tips · Memory definitions. MEMORY ABCs. Memory, which is commonly referred to as RAM
Installing PC computer memory Additional information and help with isntalling PC computer memory. ... Installing a PC computer memory. Question:. Installing PC computer memory.
Determining type of hardware within computer Reference, Issue / Question. Memory, Information and help with computer memory. CH000149, How to determine system resources / RAM available?
Buying tips on computer memory. How much memory should I get? This question really depends on the type of computer user you're and what type of programs you plan on running on the computer
Determining what type of memory to use in a memory upgrade. Determining what type of memory to use in a memory upgrade? Question:. Determining what type of memory to use in a memory upgrade.
E-mail CHID: 5683
Good Luck read and follow instructions will find your answer.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | Dell Dimension 8250 PC Desktop
Ddr ram for my motherboard
PC2100 is DDR266 memory. PC2700 is DDR333 memory. PC3200 is DDR400 memory All are backward-compatible with PC2100. Memory is designed to be backwards compatible, so generally you can safely add faster memory to a computer designed to run slower memory, but... your system will operate at the speed of the slowest memory module or system component. Keep in mind that the memory does need to be the same type, for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. ZT3000 "Beta tester of "0"s and "1's"
Aug 25, 2007 | EliteGroup P4VMM2 Motherboard
HP Pavilion dv6225us Entertainment - Turion 64 X2 TL-50 / 1.6 GHz - RAM 1 GB - HDD 120 GB - DVD RW  PC Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
