My Phillips 52" LCD TV won't turn on...it is just
  • 1,238 Answers
It possibly you have shorted power supply board or inverter board that cause of clicking sounds..
try to unplug the inverter board then try again if the indicator lit in blue you have shorted inverter board that need to be replace.
Posted on Nov 06, 2012
  • 1039 Answers
SOURCE: wont power on makes clicking noise
Replace any swolen capacitors in power board.
Posted on Apr 25, 2009
SOURCE: Tv makes clicking noise but won't turn on
Definitely a power supply problem.I had the same problem and changed the power supply, and TV works normally. Depending where you buy the unit, it shouls cost around $150/--, and it is very easy to replace.
Posted on May 06, 2009
ssebata paul
  • 159 Answers
SOURCE: phillips plasma wont turn on
check power supply
Posted on May 30, 2009
  • 100 Answers
SOURCE: Phillips TV clicking sound, then cuts off
The problem of that is a loose solder on the board..
Posted on Aug 07, 2009
  • 6 Answers
SOURCE: I have a Samsung 52
easy fix. check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/
Posted on Sep 01, 2009
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
I have a Phillips flat panel tv that won't come on
The clicking sound is the switched mode power supply trying to power up the TV. This problem is usually caused by parts called capacitors on the power supply board going bad. You can repair the board yourself by replacing the capacitors. On this model there are 4 main capacitors that will need to be replaced. If you feel that you can do the repair yourself then get back with me and I will help you get the right parts, if not you can take the unit to a repair center near you and they can replace the power board. tech@ccl-la.com
Jul 24, 2012 | Televison & Video
My samsung tv is making clicking noises and won't turn on
Clicking noises may mean a power supply voltage is not staying correct or that board is bad---a suggestion: visit shopjimmy.com who has by model number a list of all the boards used in almost every Samsung Flat screen set made.
Jun 17, 2012 | Samsung Televison & Video
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
TV won't turn on. I hear a clicking noise near the power supply. I have no picture or sound
This is usually and most likely caused by the power inverter/board. There are capacitors and other components that can burn out and will cause the power not to be transfered correctly
Jun 06, 2012 | Sony BRAVIA KDL-52W3000 52 in. LCD...
MY LCD PHILLIPS MODEL 42PFL3704D/47
Good day!!!
if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
Mar 11, 2012 | Philips 42PF9431D/37 TV
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
