Question about Canon PIXMA MX300 All-in-One Printer
Printer offline or does not respond
Printer suddenly will not print...error reads 'printer offline'. I tried the simple fixes: turned printer off/on; shut power off/on; reloaded printer software; restarted computer; defragmented hard drive. I checked the memory...512 RAM.
There was minimal use of the computer between print jobs...one day the printer printed properly and several days later it did not. There were no computer errors, shutdowns, etc. that might have caused some interference.
    Sergeant:
    Scholar:
  • 199 Answers
Oh my friend. just click the printer icon 1)click start on task bar. 2)go to settings or printer and faxes options. 3)in there you can see the printer icon 4)just right click that printer icon 5)there u will get the option 6)beside of which option there is a tick mark that is applied/enabled. 7)if there is tick mark beside the pause printing and offline option. 8)just click that option and that tick mark will go away and it will start working.
Posted on Jan 05, 2009
Message error queue says printer is offline
Try turning it off, pausing for a minute, and turning it back on again
Jan 08, 2013 | Epson stylus nx110 All-In-One InkJet...
My HP Officejet 6210 All-in-One printer goes offline whenever I don't use it for about 15-20 minutes, and when I put it back online, nothing happens. Looking at the printer from the control panel, I see...
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer
While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have a cannon inkjet mp560. when ever I try to print it says "printer is offline" or "printer is not responding. I've tried unplugging the usb cord and turned it off and restarted it, but it will not...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
It suddenly went offline after printing a document. When I turn it off & on again, it manages to print the current job but then goes offline.
Turn off the SNMP option in the TCP/IP printer port Properties
Right-click the printer, select properties
Select port tab, highlight port, click Configure Port
UnCheck SNMP status Enabled.
This fix was given to me from Xerox Tech support.
Jun 22, 2010 | Xerox Phaser 3200MFP/N Laser Printer
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
HP 1315xi psc all in one error offline
Go to Control Panel- Printers
Right-click on your printer and click on Use Printer Online.
Hope this helps!
Aug 03, 2009 | HP PSC 1210 All-In-One InkJet Printer
False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Wireless printer doesn't print (HP LaserJet 1320 NW)
GO TO PRINTER MENU AND CHECK THE JOB IN QUE AND CHANGE FROM OFFLINE IT TURNS TO READY
Nov 25, 2008 | HP LaserJet 1320 Printer
Canon Printer Help.
I have just got a Canon PIXMA MP210 ALL IN ONE PRINTER My CD ROM reader is not working how can I install it
Jul 22, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MX300 All-in-One Printer Logo
398 people viewed this question
old marine
old marine
