Question about Kitchen Ranges
I wana fix the time for this stove - Kitchen Ranges
Press the clock sign. CLO letters should appear. set the time on the numbers pad. press start. time is set. check to see if its am or pm.
Posted on Nov 09, 2012
    Problem Solver:
  • 5 Answers
Tahts should help
http://www.ehow.com/how_7419929_set-digital-stove-clock.html
http://www.youtube.com/watch?v=iQU9Kv2yfvc
http://www.ehow.com/how_8153132_set-clock-kenmore-elite-stove.html
Posted on Nov 06, 2012
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Gas stove cooktop electric pilot light keeps clicking and wont shut offf
sounds like you have it handled...
Easy?
just a phone call away... this time , when he fixes it , watch what he does... so you can fix it next time.
Mar 24, 2013 | Tappan Kitchen Ranges
The electronic ignition (piezo lighter) on my Coleman 2-burner propane camp stove just quit sparking to 1 burner. It still lights the 2nd burner. A fix?
I've had this issue a few times. Complete cleaning of the under side of the burner and all components of the ignition system fixes it every time.
The slightest bit of carbon build up is the probable cause. I would suggest cleaning the contact with 400 grit or higher emory cloth. This will remove any contamination from the ignitor,
Aug 06, 2012 | Coleman 2 Burner Camping Propane Stove W/...
What do you do when ur razor e200 electric scooter stops working?
First try charging the battery, if that doesn't work then replace the batteries with replacements from razor.com. This should solve your problem
Jan 15, 2010 | Razor E200/300 Electric Scooter Battery
CODE F7
Most models it will be a stuck keypad. You can try pushing all keypads several times each to try and un-stick the key.
If that does not work you will have to replace the ERC. (clock).
May 27, 2009 | Stoves Kitchen Ranges
What does F-1 mean on the electronic display of stove?
F1 is a failed thermistor control in the control board. Board must be replaced to fix. Part is in vicinity of $120.00
May 20, 2009 | Hotpoint RGB745 Gas Kitchen Range
Broken glass top range
im sorry about that.i have replace many of those running around 400$,that a lot of money.i have see glass top stoves on sale 4 that much.and i think they all are about the same as quilty goes.God bless,tom
Jan 02, 2009 | KitchenAid KESC308LSS Electric Kitchen...
Coleman Peak 1 Model 400 stove We have had this stove for 20 years at least. The last couple years a problem has begun and has gotten worse. The stove will leak liquid fuel all over the base which then...
I have heard two things that could improve your stove. I had the same "bursting into flame" issue last weekend while camping. First, move the black handle back and forth a few times. That is supposed to clean the jet. Second, take the generator off and hit it with a blowtorch. That should clean out the deposites on the inside. Or you can purchase new generators (just make sure you get the correct one).
Aug 03, 2008 | Kitchen Ranges
Stove won't stay lit!!
So, you cleaned the burner per the manual (or the one you looked at when visiting the appliance store,) and it still flames out right after coming on? Sometimes things catch in the works and there are a few methods to clear them out (e.g. at the controls) depending on the model. Beyond that,in order to disconnect the stove and check the inlet filters, you might want to call the appliance or gas co for a technician. No use having leaks, searching forever for the main shutoff valve, etc.
Mar 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Kitchen Ranges Logo
254 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
