Toshiba 51hc85 will not show picture red power light flashes where is reset button and or fuses What else could it be
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
This set does not have a reset button. The flashing light means shutdown and the most common cause is a short in the Convergence circuit.
Way to prove or disprove this is someone has to get at and unsolder both chips used--usually two stk-392-110 or similar--18 pins each.
If set comes on then one chip is bad but both must be replaced.
There are resistors around the chips that fail and that triggers the shutdown. Also most of these have pico fuses that are not glass and are tied to different areas of the set--one of them goes and shutdown is the result--they are green or orange and look like a resistor but have the amperage marked on the board next to them---two of them protect the convergence circuit and are usually 3 to 5 amp---can be tested with set unpowered just like any fuse--no reading across and bad.
set may have as many as 7 of these all in or near the power supply.
Posted on Nov 06, 2012
SOURCE: kds55a2000 red light flashing
The SONY Owner's Manual for the KDS55A2000 does not state what the 4 times blinking Power LED means.
However, my Sony Extended Care Service support insists that the projection lamp is the cause for the 4X blinking LED
Power light.
I do not agree but am forced to buy a replacement lamp (not cheap) to prove that the problem is probably the fan, as the TV Technician states elsewhere in these FixYa support questions and answer
Posted on Nov 29, 2007
techman
  • 3130 Answers
SOURCE: Toshiba 57H81 Blinking power light
This sounds like the typical toshiba power regulator ic fault. it begins with an str##### Its not something a handyman should try to tackle. It should be repaired by a quilified repair person Sorry Good Luck
Posted on May 22, 2006
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
SOURCE: toshiba theaterview red light blinking
new power supply
Posted on Nov 10, 2007
SOURCE: Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Posted on Jan 05, 2009
Flashing red power light on my toshiba projection tv model 51HC85
Power supply is blown change caps inside on the power supply board
Mar 03, 2017 | Toshiba Televison & Video
Greetings,
Power supply cannot sustain / provide juice to the whole system.
If you are qualified to do electronics, check the power supply section, otherwise contact a repairman.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 29, 2008 | Toshiba 57H81 57" Rear Projection...
I have a toshiba 51HC85. It will not power on the power button is flashing and we smelled a strong oder like something was burning
First is UNPLUG AND DO NOT TRY TO USE THE SET AGAIN.
Have someone who knows what they are doing open set now and look for burnt parts--the smell may lead you to the area where problem is.
Mar 28, 2012 | Toshiba 51H93 51" Rear Projection HDTV
My tv has a red button on the front that flashes and no picture comes on when we try to turn it on with the remote
The Toshiba sets were well known for bad capacitors in the power supply. I recommend getting it assessed.
Mar 19, 2012 | Toshiba 32AX60 32" TV
My toshiba TP50H15 color tv comes on then off and the light blink
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Dec 05, 2009 | Toshiba TP50H50 50" Rear Projection...
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
Repairs Made:
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba TV problem
No reset button, try unplugging the set for 1 min, the plug back in, otherwise Tv Tech time.
Jul 08, 2007 | Toshiba 36AX61 36" TV
Televison & Video Logo
265 people viewed this question
Top Televison & Video Experts
Electro Med Services...
