Question about Dell Dimension 4600 PC Desktop
Drivers Hello, a friend of mine has a 4600i, the sata H/D failed. She bought another 160 gb (used), we formated and then she informs me she cannot find her cd's that came with the pc. I installed xp pro and now the pc is really slow. It used to be lighting fast. Can you please help her, she's bugging out on me. I know it must be a driver problem, but why is it so slow? I know nothing about sata drives. thanks, mike
  • Mike Parker May 25, 2007
    I should have told you, the computer reconizes the sata drive. I finally figured it out, I had the Hyper Threading on in the Bios. Turned it off and reinstalled xp again and now were cooking.
    Thank You for your help,
    Tidefan
    President:
  • 2,961 Answers
You have probably not installed sata/raid support floppy disc on the initial install of windows when prompted to press F6. You will need to find the make of the drive, then go to the manufaturer web site and download the HDD drivers to a floppy disc. The motherboard may also need the driver for sata/raid from the dell support site http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
Posted on May 22, 2007
I have Hitachi Deskstar 7K160 HDS721616PLA380 160 GB SATA Hard Drive bios is detected but we cant format
If the operating system can't format the hard drive then the chances are that the drive is either failing or Failed.
Mar 19, 2012 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
150gb sata formated hdd not recongized by lenovo 3000 n200
ok..let's do one thing at a time...can you boot to F2, and see what your bios states is the case?
May 25, 2008 | Lenovo 160GB FDE 5400rpm SATA for ThinkPad...
The beast refuses to recognise my SATA drive
Hello the homepage is here:
http://www.pcchipsusa.com/PCCWebSite/Products/ProductsDetail.aspx?detailid=356&CategoryID=1&DetailName=Driver&MenuID=1&LanID=0
Look for any drivers missing, i the device manager.
Especialy the chipset driver: VIA HyperionPro Driver.
And use windows update, for the latest service pack release.
Good luck
Nov 13, 2011 | PC Chips A21G Motherboard
Windows 7 need a hard drive driver compatible with my hardware. I bought a new laptop hard drive - Western Digital SATA 500GB - 7200 rpm drive. It is formatted, and when I load windows from boot drive it...
WD hard drives use drivers that are built into the operating system (OS). It is extremely rare for the built-in drivers to become damaged or corrupted. The most common reason the operating system fails to recognize a drive is that the drive is defective or damaged.
Jun 10, 2017 | Western Digital (WD5000AAKS) 500 GB SATA...
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
When I attached 2.5" SAMSUNG
You may have a driver mismatch ,your HD may require
USB 3.0 driver or Sata compatible MOBO
Feb 14, 2011 | Samsung HM500JI 500 GB SATA Hard Drive
Hard Disk Toshiba MK1646GSX
Change setting to SATA as this is a sata/300 drive.
Jul 10, 2008 | Computers & Internet
Change of hard disk from 160 gb ide to 250 gb sata
Hello there.
I checked the specifications on your motherboard from here .
As you can see it does indeed support SATA Hard Drives, as per the page:
SATA Four-Channel Serial ATA supports 4 SATA II devices
Each SATA hard drive uses up 1 of the channels, so you can use a total of 4 SATA drives at once.
Hope this helps.
Jun 16, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Problems Installing my 160 GB Seagate SATA HDD
you need to go in bios and set sata to legacy for no F6 driver. if its on native it need a driver from floppy on xp cd boot . if its not detected in windowws as a slave. u need to run diskmgmt.msc and fin the unalocated drive and create part then format it ntfs
Nov 05, 2007 | Asrock K8Upgrade-VM800 Motherboard
Hard drive
My friend you need to be more specific in order to help you, what is the question?
Aug 30, 2007 | HP Pavilion dv9205us Notebook
Dell Dimension 4600 PC Desktop Logo
121 people viewed this question
Clive
Clive
Alun Cox
