How to get rid of CL code - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Child lock code?
Posted on Nov 06, 2012
My LG WM-14331FD washing machine has error code CL. How do I get rid of it please.
CL is child lock, just press the child lock labeled button for about 3 seconds. with the unit powered on.
Sep 16, 2016 | LG Washing Machines
Cl code error how do i get rid of it.
Norah, The simplistic fix might be to unplug the washing machine from the wall socket, wait 5 minutes plug it back in and see if that clears the error.
Jan 29, 2014 | Bosch Washing Machines
97 Honda multiple misfire at operating temperature
Yes fix the leak but a faulty Knock sensor will trip a miss fire code. Yes get rid of those iridium plugs and see if that works first because iridium is a higher burn temp. and more temp doesn't mean more power! There is a specific code for a knock sensor but many things can cause the same result. After my friend replaced his motor in his prelude he had the same problem with multiple miss fires and other codes but he changed his knock sensor and cleared it right up!
Parts For Porsche Cayenne
Jun 11, 2012 | 1997 Acura CL
I have a smart max star oumo 1.5 and it will not pull enough water to run vacume. i have had for two years and now when i first kick on pulls hard the slows down.My pool looks like a frog pond.do i need...
Read all my comment before you choose a course of action:
Is this above ground? If yes, dump the water and start again. Whether in ground or above ground, back wash the sand filter, if you have sand, replace the DE if a DE filter, if a cartridge filter - replace the cartridge. Better yet, get rid of the cartridge and get a sand filter with capacity for your pool.
If in ground, get rid of as much water as you can without danger of (1) popping the pool out of the ground due to ground water (2) bankrupting the budget.
With new water, treat for metal with a sequestering agent. If you don't, when you add sanitizer, the water will turn green or brown from the metal. Follow bottle instructions for the sequestering agent. You will also stain a gunnite pool with the metals.
While this is going on - check your pump for impeller damage - over haul your filter. Get your filter running and leave it running 24/7. When this is done, get your water in balance. First, get the calcium to 300 PPM, Second, get the Alk to 100 ppm. Next get the pH to 7.4 ... these steps may take days ... don't try to do this in one quick afternoon. Dose your pool with several small doses of chemicals not one big dose. Add chemical to water - not water to chemical.
The final step (with your filter running for sure) introduce CL to the 4 or 5 ppm level.
If you don't want to do these steps, and just want to get the pool clear do this: Get the filter clean (you dont say what kind of filter you have ... so I will just say GET IT CLEAN) Raise the CL to 20 ppm. Get a filter aid product and use according to contailer instructions. Let the filter do its thing for at least 24 hours before you clean it again and try it again. If you are using liquid CL, you must protect it with cyanuric acid at the 80 ppm level. Dry CL normally has cyanuric acid built in - check the label.
Metal, algae; big problems in pools. Get rid of them - Brush your pool at least one time per week. Maintain sanitizer at 4 ppm or better - shock the pool to the "break point" if you find Combined CL (Combined CL is Free available CL + Total CL = combined CL) Your pool supply place can teach you about "break point" which will release the CL from the contaminents and allow the CL to go back to work. If yor pool smells like CL you must follow the "break point" CL procedure.
I hope this helps you get your pool going ...
Thanks for your interest in FixYa.com If I did help you - please rate this response. Thanks
Aug 07, 2010 | Armco Industrial Supply C Pool & Spa
12500 gal pool began by adding 8 \ 40# bags of
Drain this pool, give it a good cleaning and start over. Clean the electrolytic cell. Your 24" x 52" size pool holds 12,481 gallons of water and requires 310 pounds of salt at initial startup. You should set the timer to run 11 hours per day. If the low salt light comes on add 85 pounds. You need an owner's manual. You can download one here. http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
After poweroutage message window shows constantly flickering"CL"
i want airtel mobile numbers pre and postpaid in hyderabad and secunderabad.
Mar 30, 2009 | Vtech Cordless Phone Battery for 2429,...
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
System keeps flashing with CL
Program the clock. There are a some buttons on the back of the base unit that sets day of the week, hour, and minute.
Dec 18, 2008 | General Electric 28031EE3 5.8 GHz 1-Line...
Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Mar 14, 2008 | Dishwashers
Code cl
Which phone is having problems? the base? one handset? All? CL... Check Line?
Jun 17, 2007 | GE 28112 Trio Cordless Phone
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
