Video Inputs for Denon AVR 589
I can't get other components to work. I running a HDMI cable from my cable box to the receiver. I'm trying to hook up an analog DVD player using an S-Video cable. Since I'm using a HDMI cable for the cable box, do I have to use a HDMI cable to hookup my DVD?
  • kerrylambert Jan 07, 2009
    I thought that was what I was reading. Thanks for the confirmation.
    Scholar:
  • 73 Answers
Manual is here: http://www.usa.denon.com/AVR-589-OM-E_006.pdf
Note on page 11 says "because video signals are out put from the AVR-589's monitor output terminal IN THE SAME FORMAT AS THE VIDEO SIGNALS, THE MONITOR OUTPUT TERMINAL SHOULD BE THE SAME TYPE AS THE TERMINAL USED FOR INPUT."
You cannot mix the HDMI with the others. You must therefore use the same on DVD and Cable box.
Best Regards and happy new year!
Charles
Posted on Jan 05, 2009
  • charles durando Jan 07, 2009
    Yes, seems the manufacturers of these lower end amps are always finding ways to misclarify or lead customers. You would think that it should work, but to find the conversion like you want, you have to get into their 1200. dollar amp.
    Glad I could help.
How do I get HDMI cables to sync or talk to each other. We had this problem when we hooked up an Apple TV box to a Denon AVR-E400 and our Sony HD TV. We were told to disconnect all HDMI cables unplug
Personally I would use an RCA cable and hook up the AVR.
((RCA out of TV to AVR audio in))
((cable box HDMI cable output to TV HDMI Input1))
(As far as the AppleTv I would use a separate HDMI Input2)
If your AVR has a dvd or blue ray player Hook up a
HDMI cable out to another Input HDMI3 of the TV
using separate inputs on the tv will allow your surround system to be
used on all modes(CABLE,DVD/BLUERAY,APPLETV)
Sep 27, 2014 | Denon AVR-E400
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
No picture with cable to denon AVR-589
Long and painful answer!!! However, in the end, you need to bypass HDMI thru your receiver and go direct to the TV. Connect Digital Coaxial or Optical for audio to your receiver. Your version of HDMI in your receiver is not compatable with today's HDMI version. Yours is 1.1a and the current version is 1.3b going to 1.4. If you want detailed info as to "why", just google "HDMI 1.1 problems" you can read for hours! Sorry for the bad news! However, it is what it is. Hope this helps. If you need further help with setup, post a comment and I can give you further help.
Feb 28, 2010 | Denon AVR-589 Receiver
Denon AVR 1610 hdmi to component video conversion missing?
hello i believe your problem is that you are trying to downconvert from hdmi to component connections and Denon receivers will not do that.
I have a 4310 and I know it will UPconvert from an analog signal to HDMI but won't do it the other way around.
you may have to use component inputs for all your equipment. You will also have to go into the receivers menu and designate which signal is being used for each component as it won't auto select between analog and digital signals when it comes to video.
hope that helps
Dec 30, 2009 | Denon AVR-1603 Receiver
How to hook up a Wii to a Denon AVR 1708
If you are video switching through the Denon, you may need to make sure the inputs (analog, composite) are the same as the outputs. For example, you might have component out to the monitor, but composite in from the Wii. I don't believe the 1708 can do the upconversion. Try hooking up a yellow RCA cable from video out to the TV.
Dec 28, 2009 | Denon AVR-1708 Receiver
Connection problem with HDMI cables on Denon AVR-589
I want to clairify you install, you sat you have I an HDMI cable running from the Time Warner Cable box to the AVR-589, going in to the TV/CBL input. From the Denon AVR-589, I have an HDMI cable running from the output to my Toshiba RV525U television.
Check the connection at the TV, if as you indicated above you have an HDMI cable from the HDMI out from the Denon to an HDMI output on the TV, if this is the case you need to have that HDMI cable plugged into an input on the TV not an output
Feb 27, 2009 | Denon AVR588 Receiver
Connection problem with Denon 589 and direct tv
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 08, 2009 | Denon AVR588 Receiver
No video
The Denon does not down scale you can not plug a DVD or other device in to the Denon using HDMI and have it come out Component, if your projector only has Component video inputs you must use Component video connections from the DVD and Cable box to the Denon
Jan 02, 2009 | Denon AVR-3805 Receiver
No Video from Denon AVR-588
It cant up-convert component to hdmi. Input and output has to be the same. However, you wont lose anything cuz hdmi and component are comparable
Nov 24, 2008 | Denon Audio Players & Recorders
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
206 people viewed this question
 Grubhead
Grubhead
