2010 kawaski brute force atv spitting and sputtering
Runs good idling then when you give it gas it does not want to run
    Problem Solver:
  • 13 Answers
Spray some carb&choke cleaner in the intake while revving it up. if it smooths out then it is a fuel problem. if not most likely in the ignition system (spark plug, wires, or ignition coil) judging by the fact that it idles fine it sound like a coil. ( this next section risks you getting shocked but you wont be harmed, mostly just surprised and a little pain.. ouch) listen for a distinct click sound of a spark. if you can hear this follow the sound and look for the spark. you can also spray the wires with water to see if they will "leak" voltage from the insulation. you can disconnect the coil wire from the coil and hold it close to the coil where the coil wire attaches to the coil and start the engine. with it idling you should be able to pull the coil wire away about a quarter of an inch or more and see a bright blue spark. if the spark is red than the coil is weak. while doing this test hold the wire close to the coil but far enough that you can see the spark and rev the engine like you would when it would sputter. if the spark seems to stop occasionally or gets dim and red then replace the coil. if none of these things happens then reconnect the coil wire and check all cylinders with this test.
Posted on Nov 06, 2012
My Durango starts if I give it gas and stalls when I let off the gas won't idle, help what to look for?
My car dies when I let off the gas - CarGurus
www.cargurus.com > Questions > Dodge > Durango
CarGurusDec 5, 2012 - My car dies when I let off the gas - I have a 2000 Dodge Durango SLT, I bought a month ago. I noticed it had a slow start but it still started and ran fin... ... Also, the oil pressure was high until it could idle by itself then it was back to normal. ... sometimes if you give it more gas it stays running but now it won't ...
dodge dakota idling and dying - CarGurus
www.cargurus.com > Questions > Dodge > Dakota
CarGurusApr 12, 2011 - dodge dakota idling and dying - My dakota will start then idle down and die. I can pump the gas and it will stay running but if i hold the peddle down or . ... thatdies on me at stop signs and when I take my foot off the gas pedal. .... and truck pops..misses and runs like crap and wont stay on unless i give it gas, ...
Truck starts but won't stay running...?? - Dodge Dakota Forum
www.dodgedakota.net/boards/v8/4240.html
Aug 9, 2003 - 21 posts - ‎20 authors
Dec 21, 2015 | 1999 Dodge Durango
93 subaru imprez.when warms up it starts
Sounds like it's getting too much fuel because is still in cold start mode by computer. This is because of a faulty heat sensor. Once the heat sensor tells the computer it's warm, it runs fine, IF the sensor is working. If not, the computer doesn't know any better than to keep it in cold start mode. I hope this makes sense to you.
Oct 12, 2014 | Cars & Trucks
Clean your IACV and throttle body butterfly valve, get throttle body cleaner at any auto parts shop.
Oct 12, 2014 | 1993 Subaru Impreza
I have a 1994 Intruder. It only starts and runs
The hot side is running way too lean. Have your carbs synchronized may help. Try draining the bowls. Good luck.
May 28, 2010 | 1994 Suzuki VS 800 Intruder
When i start the truck up it will not idle
Is the engine at running temperature when it starts running rough? And when it is cool does it run fine until it warms up?
Jul 28, 2009 | 1993 Chevrolet C1500
Fluchuating idle & bucking, Like a running out of gas sensation.
how many miles are on the bike? those are the symptoms of needing a valve adjustment. if valve clearances ar good , it's in your fuel system.
Jun 14, 2009 | 2006 Suzuki SV 650 S
Hard to crank onse running it runs good at a idle
check the fuel filter and pressure regulator.
Apr 07, 2009 | 1988 Jeep Comanche
Runs good when on the gas but wont idle
You might try adjusting the timing on the carborator.
Feb 19, 2009 | 1983 Ford Econoline
Hard start and stalling with back fire when give it gas fast
sounds like you have spark plugs mixed up ever had them replaced
Nov 16, 2008 | 2002 Chrysler Sebring
Computers & Internet Logo
David Payne
David Payne
