My sharp 32" lcd tv is showing vertical lines, not
  • 1,238 Answers
Already answered
Posted on Nov 06, 2012
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: vertical flickering color lines instead of pictures
Soory man there is no deflection yoke or vertical output IC in a plasma TV set.LOL This person has a problem with whats called the substain power supply or bad caoacitors in the main supply. there is also a possibility that the set has a bad tuner. Only performing test on the set will determine the problem.
Posted on Mar 23, 2007
  • 84 Answers
SOURCE: Sony Grand wega KDF-E50A10
unfortunately the B Box assembly needs to be changed in these and price of the part alone is more than half the cost of a new tv
Posted on Apr 19, 2008
MNfisherman
  • 11896 Answers
SOURCE: 32'' Insignia LCD is flashin colrs. wh,blk,rd,grn,blu. audio wrks
It could actually be quite a few things, loose wire, loose solder piece, bad crt's/picture tube, bad system board, or others. It's would have to be diagnosed with testing equipment. It will probably cost you another 150-200 for the new part to be put in.
Posted on Jan 28, 2009
  • 98 Answers
SOURCE: My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Posted on Feb 06, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Green vertical lines across the screen.
Green lines on LCD screens generally means physical damage. Did you drop it or bump it by chance? Physical could also include the cable that you are using. Try using a different cable, or make sure it is connected all the way.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Mar 05, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp 32" lcd tv vertical lines on screen
sounds like you have receiver connection problem..
To test it try to play dvd on your TV..if the picture is fine your TV is good..your problem is on the cable box or receiver..
Nov 06, 2012 | Sharp LC-32AV22U 32 in. LCD TV
Sound but no picture with vertical lines
its sounds that you have a bad t-con board, but before you come up in trouble shooting with in the t-con board. you must check first the power supply board if has bulging electrolytic capacitors and common is leak.
Oct 10, 2012 | Element Electronics FLX3210 32 in. LCD TV
I have a sharp 32av22u which has vertical lines and at moments i get a picture and sound and then lines appear and screen fades to multi color but still have sound
This is a problem with the LCD's inverter cable, the cable that connects the LCD to the mainboard. Have it checked, reseated or replaced by a certified technician to prevent damage of other parts.
Sep 05, 2011 | Sharp LC-32AV22U 32 in. LCD TV
My Sharp tv has vertical multicolored lines that
my new lc60le820un sharp is doing the same thing after two weeks. i called sharp they want to fix it. i want a new tv. after a few minutes of this i hung up and and called hh greg to replace it with a sony. thanks hh greg the sony is fine
Nov 26, 2009 | Sylvania 32 in. Diagonal LCD HDTV
Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
May 15, 2009 | Sharp LC-52D62U 52 in. LCD HDTV
Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Dec 24, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
