Question about Dryers
No water coming into water container
Clothes getting hot but damp not drying properly and no water in water container
  • Dryers Master
  • 8,220 Answers
Sound like you me yall need to yank out the condenser and give it a clean. Sweet video here:
https://www.youtube.com/watch?feature=player_embedded&v=Q-n5Jmv-yG0
Posted on Nov 07, 2012
Vish2
  • 74 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Posted on Oct 11, 2007
SOURCE: Clothes not drying...
need a new thermostat
Posted on Oct 17, 2007
  • 1314 Answers
SOURCE: Dryer heats up but isn't drying properly
yes it does something is blocking your vent either its all coiled up behind the drier or something i need to ask a few questions go out side and look at where your drier vent has a hood make sure nothing is blocking it from opening it has a little round door on it ive seen some that have little plastic screens on them that gets clogged the screen is there to keep critters from building nests in the vent line then get a flash light and look over the back to see if the vents folded over mashed etc to find out if its a vent problem take your vent loose dry a load and see if it goes back to normal if all that's ok get back to me and we will clean the drier i need to know if your lint screen is on top or in door and your model #
Posted on Jan 02, 2008
maklean
  • 1665 Answers
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
MNTECH
  • 1543 Answers
SOURCE: Dryer is getting hot but clothes are not drying
You have a vent problem. Eliminate all (if possible) flex duct (replacing with ridged aluminum pipe and aluminum elbows). Clean lint out of remaining vent pipe. Make sure vent is not crushed or obstructed, especially behind the dryer. If possible, make sure outside vent termination is not a two inch opening. (you want a full 4 inches)
Posted on Nov 10, 2008
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
After drying a load of rather damp clothes, the 'emty out container' light keeps coming on (there is a loud peeping noise and the dryer stops) even though the container is empty. The container is not...
This may help you. Please give the person who answered this thread credit if this helps.
http://www.fixya.com/support/t277592-bosch_classixx_condenser_drier
Apr 07, 2011 | Dryers
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Jul 20, 2010 | Electrolux Washing Machines
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Takes 3 cycles to dry clothes even on towel cycle
If the clothes are hot when they come out but moist or damp it mean the moisture is not getting vented, Check your vent pipe for blockages or leaks.
Apr 30, 2010 | Frigidaire Affinity AEQ6000WH Dryer
The unit spins and clothes get hot, but no water collects in the water container. So things aren't drying...:(
if the water container is located at the top,then the pump is probably defective.
Oct 07, 2009 | Dryers
When clothes are dryed on the perm press cycle either reg dry or very dry, they are still damp. I have to run it through 2 or more times to get them dry. I'm told by Bosch that is what perm press is...then...
You may not be getting sufficient air flow--remove the lint filter and wash it with detergent and hot water. Also clean excessive lint out of the air vents (under the filter too). Don't use 'perm press' if you want things absolutely dry. Remove and hang up before they cool. 'Damp dry' really means 'don't dry' I guess!
Aug 28, 2009 | Dryers
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Clothes Hot but damp, water out of vent
Is this a combo washer/dryer in 1 unit? water shoud not come out if it is just a dryer. Your air coming out of the back vent hose should be hot. If your clothes comes out of your WASHER damp (more than normal) then your washer is not spin drying good enough. (worn belt, clogged drainage system).
Jan 09, 2007 | LG DLE2532W Electric Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
