Question about Lasko 655702 Stanley Blower Floor / Box Fan
Lasko blower fan only blows on low
Only blows one speed, not 3
4 Suggested Answers
SOURCE: lasko 2554 tower fan
Replace motor. Probably cheaper and less hassle to buy another fan, unless you are about principles and demand the company replace their subpar motor of an otherwise exceptional fan.
Posted on Apr 14, 2009
protek480
  • 1714 Answers
SOURCE: my lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
Posted on Jul 22, 2009
jstonefish
SOURCE: How do you clean a Lasko® High Velocity
How do I clean out a lasko high velocity blower fan?
Posted on Aug 09, 2009
Lasko fan wont blow air
Sounds like the fan motor is the problem
Aug 31, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko 18" cyclone 1843 quit working is there a fuse
  • Lasko Cyclone fans have a thermal fuse (typically 130 degrees C) placed on the armature of the motor, connected between the input voltage line and the start capacitor. It is not user replaceable, since it is soldered, taped and attached to the armature with cable ties. When the motor overheats, the thermal fuse blows, primarily protecting against a fire hazard. Like most low cost Chinese manufactured fans, the motor uses low quality sintered bronze bushings instead of ball bearings to save a few pennies in cost. The bushing (each motor has 2) is surrounded by padding which is infused with lubricant, and the lubricant seeps through the bushing to lubricate the rotor shaft of the motor when it is operating. Unfortunately over time, the lubricant dries out or the bushings clog, causing the rotor friction to increase, resulting in the motor current increasing as it tries to maintain motor speed. This heats up the armature coils, causing the thermal fuse to eventually blow. While the thermal fuse can be replaced with some effort and the padding re-lubricated, eventually the same thing will happen because of the low quality bushings.
Jul 05, 2014 | Lasko 3520 20-Inch Cyclone Fan
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
1997 Merc Mystique heater fan only works on low
Hi Scott,your blower motor resistor may be bad,here's what it looks like,it located next to the blower motor,easy to remove.
Jan 30, 2013 | 1997 Mercury Mystique
3 speed blower switch only operates at one speed on all settings
hi,
ur blowers switch may be faulty. it need to be replaced.
ok
Dec 27, 2010 | Lasko 655702 Stanley Blower Floor / Box...
How do you clean a Lasko® High Velocity Blower Fan w/Remote
you need to dismantle the fan,
the top back pry off.
then you will see screws.
Aug 01, 2009 | Lasko High Velocity Space-Saving Blower...
Blade broke where to get new one
You can call by phone Lasko customer Service and Replacement Parts......1-800-233-0268.......givi them FAN info and they will ship you part..........................Also check, your product may be covered under WARRENTY or may be listed under product recall .......either will reduce your COST .....
May 10, 2009 | Lasko 2506 16", 3 Speed, Oscillating Fan
Heater blower only blows on low
This could be a few different things:
1.Check the power and ground connections on your blower motor, corrosion can cause high resistance and a slow blower speed.
2. Check your available voltage at the blower motor on the different settings. it should vary with high supplying 12volts, make sure to do this check with the blower motor still plugged in.
3. Connect the blower to a 12v power source and see if it runs at high speed.
If all else fails i would check your resistor pack, i would not suspect this because when it fails you usually just loose all speeds except for high, but it could happen.
Feb 25, 2009 | 1999 Chevrolet Silverado 1500
2002 saturn heater
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing.
Nov 23, 2008 | 2002 Saturn Sl
Does ac blower have a fan relay ? It doent blow ******* max
if it doesnt work on all speed its the blower motor resistor that broken thanks pierre
Jul 30, 2008 | 1979 Pontiac Firebird
Lasko 655702 Stanley Blower Floor / Box Fan Logo
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
