Question about Disney DTD1363-CAR 13" TV/DVD
Disney mcqueen tv DTP1363-CAR
Tv turns off after awhile...if you turn it back on it starts going dark then off again.
How costly are the parts to repair and can it be repaired?
Thanks
  • MzLowe Jan 06, 2009
    Yes, it will play and then it will just cut off. Can not play the dvd player either;
    Sergeant:
    Scholar:
  • 199 Answers
Yes it can be repaired for sure .it will cost you near to between  $10 to $ 150 plus the service charge of the technician. as sometimews this causes due to very minute short circuit and a small ic or capacitors gets blown and the cost for that 1 single capacitor is very negligible so it can be $10 also. thanks.
Posted on Jan 05, 2009
Repairing an LCD tv
I would replace the TV, the problem is most likely the main PC board is shorted, the part and labor is close to the cost of new.
Sep 22, 2016 | LG 47LD520 47 in. HD-Ready LCD TV
Tv keeps turning off after turning it on.
Based on the lower specification of this TV any repair is more than likely going to exceed the cost to replace it, One of the internal components has failed and generally unless you are handy with an oscilloscope it's not worth fixing.
May 04, 2017 | LG Electronics - 32LS3400 - 32 Led 720p...
Picture is rolling sometime double images after awhile it stops and then starts rolling again
Ur tv convergence are dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 25, 2010 | Mitsubishi VS-60705 60" Rear Projection...
I have an Olevia 237-t12 hdtv, I will lose the picture but still have sound, I can turn the rv off wait a couple of minutes and turn the tv back on, it will play for minutes then go dark again, but I never...
I had the same problem with the exact same TV. I took it to a local TV shop. My problem was fixed by replacing the T-Con controller board. The cost of the part was about $85 and labor $125. There are no "new" parts out there for Olevias because the company is out of business but I did find a part pulled from a "damaged in transit" TV. It's a personal decision (assuming the parts can be found) as to if its cost effective to repair the TV.
Apr 24, 2010 | Olevia 237T 37 in. LCD TV
Plasma TV picture is ''mossy''
Don't watches tv anymore or u will kill the tv CRTS tubes,will cost u more money to replaced the CRTS tv tubes than the problems u have right know.U have convergence problems,it dead.U have any soldering skill?Have solder iron,Solders,Solders wicks,Tries websites Tv repair world.com,Tv repairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300-$400 for parts and labors.
Mar 29, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The convergence going bad again on my Hitachi 51swx20b
Sounds like loose solder on the chips. Either that or they are failing. You can save money next time by doing it yourself with a kit from www.TvRepairKits.com
Jan 10, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Lg 32 inch lcd on light flashing white but fast
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a badcapacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 20, 2009 | LG 32LC7DC 32 in. LCD HDTV
Hi, I have a Panasonic W32D2DP its about 5 years old. It worked fine until about 3 weeks ago. It started cutting off and going to standby. It worked fine after for a few more hours, then would do it...
It's going to be cheaper to buy a new TV. Once you get this problem solved, another one will pop up. The parts for a TV that's 5 years old are not going to be cheap. Most TV repair shops stop carrying parts after 4 years, & the manufacturer stops making them after 7-10 years. With a semi-major purchase like a TV, it's best to purchase an extended warranty. ipmart. com offers a cheap repair manual. You'll be suprised how expensive repair shops can be when it involves "out-of-warranty" work.
May 08, 2009 | Televison & Video
MY lg 32lx1d is not turning on..
I had the same sympton on my tv...it worked fine one day and the next day it would flash a green light a few times you would see the screen power on, but still be dark then the power light would go red. I couldn't do anything on the tv no menus or sound. It turned out to be a bad power supply, a new power supply will run around $200-300 - in my opinion it wasn't worth fixing. My neighbor was able to fix my tv - he repairs electronics - ended up cost me $100.00 - its been running for 7 months now no problems so far...I can have him fix this for you if you are in the area - shipping makes this to expensive..he is located in south jersey...or you can try a tv repair shop ( i called for this but they wanted between $75-100 to just look at the unit + repair cost - i would of been back to the 200-300 range) let me know if you need help...John
netplus@comcast.net
Aug 24, 2007 | LG 32LX1D 32 in. LCD Television
Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
Jun 01, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Disney DTD1363-CAR 13" TV/DVD Logo
112 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
